06-02-2005, 04:51 PM | #1 |
< 69 Blazer
Tach reading way too high ?
I bought a tack/air pressure dash from a swap meet early this year. It came from a big truck and there is an idiot light on the fuel gage for 'tandem axle'.
I replaced the air pressure gauge with a vaccume gauge and put a normal bezel on it and put it in my blazer. I hooked the tach up to my HEI (tach spade). The probem is that the RPM reading is WAY too high for what the engine must really be turning. I have a TH350, NP205 , 3.07 gears and 33" tires and it was reading close to 4000 rpm at 70mph (if I remember right). Why is my tach reading way off like that? It returns to 0 when off and reads about 700rpm at idle (but I'm guessing it really idleing around 500rpm). Could I have a 6-cyl tach? If that could be the problem did 6-cyls come in big trucks with tandem axles? |
06-02-2005, 06:14 PM | #2 |
No,I DON'T have Tourett's
most early "big" trucks were 6 cyl
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
06-02-2005, 06:35 PM | #3 |
most i have seen here are 8cyl
06-02-2005, 06:45 PM | #4 |
it will be stamped on the back of the tack 6cyl or 8 cyl. and there is a screw on the back also, it for adjusting the tack reading, try playing with it to see if you can get it to read correct, but first i would hook up a know good tack to check the one you got.
jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
06-02-2005, 07:02 PM | #5 |
Engine RPM = Gear Ratio x Speed x Transmission Ratio / Tire Diameter / .002975
Engine RPM = 3.07 x 70 x 1 / 33 / .002975 Engine RPM = 2188 You're right. It is reading way, way too high. If this is being caused because it's a 6-cylinder tach, then it should be reading 2188 x 8 /6 = 2917 RPM, which is still quite a bit lower than what you're seeing. Something else must be wrong. |
06-02-2005, 07:07 PM | #6 |
its all about the +6 inches
yeah, stock tachs sucked 30 years ago.
06-03-2005, 09:03 AM | #7 | |
< 69 Blazer
I'll pull it out and see what the tach says on the back. If it is indeed a 6-cyl, how hard is it to replace it? (if I have to buy a new tach to put in this, then I'll have too much money in the darn thing I could'a done better buying one from someone here. ) |
06-03-2005, 01:19 PM | #8 |
Even if it is a 6 cyl tach you may have enough adjustment with the screw to get if pretty close.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
