Old 06-02-2005, 08:54 PM   #1
71Rat
ran out of money
71Rat's Avatar
frame differences?
i was wondering if a 1964 chevy truck frame would be able to unbolt and bolt onto say like a 71 chevy truck? i guess my main question is are the frames interchangeable? even the body mounts?
Thank you
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 06-02-2005, 09:04 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'm going off a 3 year old memory here, but I think some one on here said they were real close, but not a direct bolt in.
Old 06-02-2005, 09:13 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
not to hijack but would the PS mod be like the 67 where you have to make the dimple or are the boxes different
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 06-02-2005, 09:18 PM   #4
71Rat
ran out of money
71Rat's Avatar
would a 67 to a 71 be a dirrect fit then?
anyone else?
Rat
Old 06-02-2005, 09:31 PM   #5
Longhorn Man
The only difference on a bare frome on a 67 to a 71, would be the dimple for the power steering box would be present on the later one, and also, the 67 doesn't have provisions for a big block. I know there is a spot on the forward passenger rail that is flaired up, that is for big block fuel pump room...
That is all that would be different to my knowledge.
Old 06-03-2005, 02:30 AM   #6
pjmoreland
pjmoreland's Avatar
There is less clearance for the engine between the frame rails on a 67. The frame rails are wider. This causes problems when installing headers.
I had a SWB 67 and it had the dimple from the factory for the power steering pump.
pjmoreland is online now   Reply With Quote
Old 06-03-2005, 08:17 PM   #7
71Rat
ran out of money
71Rat's Avatar
ok thanks, is there a problem with putting a big block into a 67's frame though? i am not worried about headers since it will be fender headers going into it.......
Also power steering dimple doesnt matter, not going to use power steering
Thanks everyone for the help
Rat
