06-02-2005, 09:16 PM | #1 |
FUEL CELL GURU
C20 Rear...
Do the C20 diffs have bigger axles that the C10's?? That may be what I have... I need a C10 rear 6 OR 5 lug. If the C20's have bigger axles, then that would explain why the 5 lug axles I have won't fit the diff that I currently have. Maybe I just confused everyone. Someone help! Later, Mark
06-02-2005, 09:20 PM | #2 |
Got Light Emitting Diode?
i am not confused, i just dont have the answer for you
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
06-02-2005, 09:28 PM | #3 |
its all about the +6 inches
The c/20 axle is nothing like the C/10 axles.
The 20 bolts to the hub and has splines on the oposite end. a 10 axle has splines on the inner end, and a c clip on the same end to retain it. |
06-02-2005, 09:40 PM | #4 |
FUEL CELL GURU
Was there a C10 "Heavy Half"?? or maybe a C10 Camper Special??
06-02-2005, 10:25 PM | #5 |
Not very likely.
06-02-2005, 10:48 PM | #6 |
Cause the Chicks DIG IT!!
hey fuelcell guy i seen your wanting to buy 5 lug 12 bolt rearend in the parts board. I'm up in Oklahoma City and I might have one for you, but its at my buddies junkyard. I'll ask him tomorrow and see if he still has it and then i'll let you know.
06-02-2005, 11:03 PM | #7 |
Heavy half....that was later...late 70's early 80's.
Custom Camper...nothing but HD springs, shocks tires and a sway bar. That's it. |
06-02-2005, 11:43 PM | #8 |
I have a radical idea!
Some 1/2 Tons came with 12 bolt GM rears and some had Dana 44's. That may be your problem. You may have Dana 44 axles and a 12 bolt rear, or vice versa. Look at you rear diff and count the bolts. If it has 12, it is a 12 bolt (you probably had that covered, huh? ) and if it has 10, it would be the Dana 44. I've never seen a Dana 44 with the coils springs in a 1/2 ton, but I'm not sure if they only came that way. The rear covers should look like either of the 2 below.
DANA 44 12 BOLT
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 06-02-2005 at 11:44 PM. |
06-03-2005, 07:27 AM | #9 |
FUEL CELL GURU
67_C-30, I know for a fact that it is a regular 12 bolt. I could use the diff that I have but I would have to have the axles redrilled.
WRMZ71, yea, check into that if you will. Thanks to all, Mark |
06-03-2005, 07:57 AM | #10 |
How are the axles too big? Too long, Too big around, What?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-03-2005, 10:07 AM | #11 |
FUEL CELL GURU
The ones in the housing now have a larger diameter spline than the one I bought that were supposed to be 71-72 axles. That's kinda where I am at.
06-03-2005, 07:31 PM | #12 |
fuelcellguy - My buddy knows he sold one of those 12 bolt 5 lugs but think he might have one left. I'll let you know as soon as I do.
