GM 7-Pin HEI retrofit
Anyone know how to make a later model 7-pin HEI dist work in an older vehicle? I understand that the 7-pin setup has electronic timing control (ESC?) which seems kind of attractive to me. I'm wondering if there is a control module (aftermarket even) you can hook up to the dist and program advance curves and so forth?
How about some good sites to read about this? Thanks |
![]() Join Date: Mar 2003
Sounds like you're gonna need a computor. 4 pin hei would be easier
you can take the module out of that dist. and trigger a msd box with the magnetic pickup.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#5 | |
