Old 06-03-2005, 12:52 AM   #1
CHEVY & GMC FOREVER
Just noticed something and I either can't remember or never knew...
Today I was driving home from a friends house in the 69' and was making a left turn when I notice in the shift indicator there was a orange blinking light but it only works when I use the left turn signal... What is this and do I need it??
1985 Chevrolet C-30 454 1-TON Dooley
1969 CHEVROLET CST-10 PICK-UP
Good memories
1999 Chevrolet Z71 Ext. cab 5.7L
Good Memories
With a quart of oil, and a gallon of gas, she won't let no other car pass!!!.
& FOREVER
CHEVY & GMC FOREVER is offline   Reply With Quote
Old 06-03-2005, 12:56 AM   #2
jhwkns
Registered Cruiser
jhwkns's Avatar
Is the fiber optic plugged into the wrong light socket?
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 06-03-2005, 01:01 AM   #3
CHEVY & GMC FOREVER
don't know, I just took the gauge cluster out and cleaned it all up and connected it back the way it was.
Good memories
Good Memories
& FOREVER
Old 06-03-2005, 01:02 AM   #4
Alexis
Member since 2000
Alexis's Avatar
yup, you broke something.
check it again cause it's getting light form the turn signal.
Alexis is offline   Reply With Quote
Old 06-03-2005, 01:06 AM   #5
CHEVY & GMC FOREVER
Is it really that important I mean it does not look like it is doing a whole lot, it only works on left turns and it does not really bother me, but I'll check it again, but is it a real important thing what does it do??
Good memories
Good Memories
& FOREVER
Old 06-03-2005, 01:07 AM   #6
Alexis
Member since 2000
Alexis's Avatar
it's not vital, heck mine didn't even light up.
Old 06-03-2005, 02:11 AM   #7
pjmoreland
pjmoreland's Avatar
Sounds like you have the shift indicator fiber optic plugged into the left blinker light socket on the back of the gauge panel. Just swap it with a gauge panel light that is not a blinker light. The shift indicator light should always be on when your headlights are on. It helps you see what gear you are in when it is dark.
pjmoreland is online now   Reply With Quote
Old 06-03-2005, 07:10 AM   #8
70c10
67-72 Addict!
70c10's Avatar
The fiber optic socket should be next to speedo on the right.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-03-2005, 12:37 PM   #9
CHEVY & GMC FOREVER
Well I can fix it today and hope it works, but I can't check it because my son left the ignition on over night and this morning I went to start it up and I see the ignition in the on position so I try to start it and nothing.... Well long story short the boy's grounded from even looking at the truck, and I got the battery charging now. So that should take a while, well when it is charged up I'll fidle with the dash, and I'll get back to you.
Good memories
Good Memories
& FOREVER
