Old 06-03-2005, 08:41 AM   #1
superchevy
Got big-block?
superchevy's Avatar
Who's done the DJM 5" rear flip kit install?
I just got the kit...not a lot to it. I've used BellTech flipkits before.
Any tips on this DJM install? Thanks, SC.
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 06-03-2005, 09:57 AM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Shouldn't be any different for Belltech vs DJM
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-03-2005, 12:23 PM   #3
beaterC10
Check for clearance with the DJM spring plates. I had to do some grinding on mine to the required clearance. I think the interference was with the shock on one side. I have had mine on about 18 months and I forget the exact point of interference.
beaterC10 is offline   Reply With Quote
Old 06-03-2005, 12:30 PM   #4
loblazer
loblazer's Avatar
I insatlled one on my 1980 2WD Blazer. No problems at all. Also Belltech drop shocks and C notch by me.
Doug
TOTM Oct 2004
loblazer is offline   Reply With Quote
Old 06-03-2005, 02:24 PM   #5
Izzy
Trucker.
Izzy's Avatar
I helped with an install using the stock spring plates and with a good titanium bit it was cake and was way cheaper than buying the deluxe kit.
Izzy is offline   Reply With Quote
Old 06-03-2005, 06:41 PM   #6
jermasaurus
jermasaurus's Avatar
It says to take the bolt out of the center of the leaf springs and put it in reverse.... you dont have to do that. (At least not on mine, 85 C10) as long as the nut fits inside the hole on the bracket it is fine. -if you can make anything from that poor explanation
Like BeaterC10 said, You may not be able to get the nut on the bolt for the shock extender, being so close to the leaf springs.
jermasaurus is offline   Reply With Quote
Old 06-04-2005, 06:15 PM   #7
Tom
driving is in my blood
Tom's Avatar
I've only done the western chassie flip kit, very easy install. Just new plates and u-bolts as far as I remember...
Old 06-05-2005, 12:56 PM   #8
chevyrestoguy
chevyrestoguy's Avatar
I bought a AIM kit about a year ago, and it was junk. The rear is flipped and the new spring plates are installed, but there is no physical way to install the shock bolt without removing the spring. I went on to another project, but will be back on it soon to either make it work or remove the kit and buy one that fits right. I've never had a problem with a Bell-Tech or Western kit, so I guess you get what you pay for.......
________
CHEVROLET TRAVERSE
chevyrestoguy is offline   Reply With Quote
