Old 06-03-2005, 10:07 AM   #1
pat
pat's Avatar
Fan options
Im trying to decide what to do with my fan. Ill be running a 383 with headers and a/c in Texas, so Ill need plenty of air moving. I was looking at flex fans, but I dont think they move enough air. I thought about electrical, but they are pricey. Then there is the stock fan.
What do you guys recommend?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 06-03-2005, 10:23 AM   #2
rambler
MOVE OVER
rambler's Avatar
I heard nothing but negitive about flex fans (not sure why) but make sure you have a fan shroud to help with whatever you use.. I dont have a/c and a standard 350 w/o headers, so with my new grill and such, I just put one 18" electic.. in the FAQ section there is a post about using a double electic off a acura I believe.. wish I saw that before buying mine.. I think one electric is good enough for me, but check out the FAQ,, that may be your answer... good luck..
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 06-03-2005, 10:24 AM   #3
sleepyboy
'69 Step
I live in San Antonio; 350 with vintage air. Switched to a 4 core radiater and dual electric fans; no problems...
sleepyboy is offline   Reply With Quote
Old 06-03-2005, 10:51 AM   #4
smokekiki
Mike
smokekiki's Avatar
This article is one of the reasons..http://www.worksafebc.com/publicatio...wsflexfans.pdf Flex fans have come apart and have caused some deaths.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 06-03-2005, 11:28 AM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I personally like our duel 12" electric fan assembly. I use them on small blocks, and big blocks without having any problems at all and I tow a couple of pretty big trailers. I am not down in the Texas heat, but I have sold many of these assemblies to guys that are. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-03-2005, 12:06 PM   #6
rambler
MOVE OVER
rambler's Avatar
Here is the link in the FAQ section...
http://67-72chevytrucks.com/vboard/s...d.php3?t=50085
Buckaroo Banzi
Old 06-03-2005, 01:56 PM   #7
chipflyer
chipflyer's Avatar
When the stock fan clutch locked up on me I replaced it with a flex fan on my 71 with AC and it worked ok during the fall and winter months but when I fired up the A/C a couple of weeks ago the truck would run a little warmer than I was comfortable. I replaced the flex fan with a new clutch and the original 7 blade fan and it was much better. Last week I replaced the 3 core radiator with a new 4 core and now the temp needle just comes up a little bit regardless of weather its warm outside or the A/C is on.
After trying the flex fan myself, I wouldn't put one back on. I give it a thumbs down.
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 06-03-2005, 02:49 PM   #8
speedracer
Blank
speedracer's Avatar
flex fan
speedracer is offline   Reply With Quote
Old 06-03-2005, 03:41 PM   #9
mocwon
Keep On Truckin'
mocwon's Avatar
Flex-A-Lite 210 low-profile, sucker, dual fans from Summit with thermostat $237 pumping out 2,500 cfm. These fit and work great down here around the Equator, I mean Texas.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-03-2005, 04:10 PM   #10
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I have that set up. I like it. Could I bother you with a pic how you have it mounted?
Here is how I mounted the top:
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 06-03-2005, 05:12 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Alot of peeps use the one WES sells or the one CHICKENWING has,
the one WES sells is in his online catalog, the other is from JEG'S,
it is #400-295 and run by alot of members here, they are both
ASA (SEE-TEN) has this one from JEG'S on all three of his rides.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-03-2005, 05:33 PM   #12
mocwon
Keep On Truckin'
mocwon's Avatar
I'd be happy to but it'll have to wait until next week since I won't be at the shop this weekend. I'm using a four-core big block radiator I bought from Four Season so it may look different than yours.
Just Passin' Thru
Old 06-03-2005, 10:58 PM   #13
see ten
WTB this ad
see ten's Avatar
Yep! All electric here! No complaints except for my light hip pocket! By the way not only will it cool well, it will increase the mpg for you.
see ten is offline   Reply With Quote
Old 06-03-2005, 11:13 PM   #14
bagged91
Out draggin'
bagged91's Avatar
While it wasn't in a 67-72 truck, I used dual elect fans on my 88 K2500. I had a built 383 stroker in that, stock 350 HD radiator and dual Hayden 14" electric fans(I believe they flowed 1800 cfm each)that I picked up locally at PepBoys(of course, I had to got to two different stores as each one only had one in stock). Fans cost me approx $86 ea and the thermostat kit to run dual fans was another $35. I bought a sheet of 18ga aluminum from my local metal supplier, cost around $20 and bent it to make a shroud to fit the radiator core, staggered the fans and cut out the circles accordingly. With headers, A/C on in the middle of summer, truck never went over 185 degree's. I am running a similar setup on my 91' GMC now with NO SHROUD and it runs the same.
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 06-04-2005, 12:26 AM   #15
Mongo
YES_____NO
Mongo's Avatar
Aww, I was disapointed I thought that link would have been the pic of a fan blade that had gone through the hood. still worth the read though.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 06-04-2005, 12:49 AM   #16
71RestoRod
71RestoRod's Avatar
When it really comes down to it, I don't think you can beat the cooling power of a clutch fan and well positioned shroud. Having said that, though... I too went with the Flex-a-lite dual fan setup ...
Here's how I mounted mine...
Mounting the Flex-a-lite takes a little bit of creativity. The brackets they provide are overly universal and really leave you scratching your head.... so I basically threw them in the trash. (I see you did too! I like your solution... looks really clean)
I'm running a 383 w/ AC also, so I first upgraded to a four core radiator. I made eight clips out of some light bar stock that hook to the top and bottom core supports. With a little trial and error I finally got them dimensioned so they hold the dual fan assembly tightly to the radiator.
Once I got the assembly mounted, I was kind of disappointed at the considerable nest of wires that sprouted out of the top of the assembly, in the location that the directions called for mounting the relay. (BTW, the relay is the sweetest part of the fan setup because it's totally adjustable and operates with variable speed depending on the demand.) After staring at it for some time, I finally ripped it out again and cut another air-bypass hole where the relay was and moved the relay to the left side of the radiator support next to where I had mounted my headlight relays. I made a new top rubber flap identical to the lower bypass.
I haven't had a chance to really stress it yet, but it seems to work really well. It cycles nicely, remains on for a short period of time after you shut down the engine, and runs at a quiet 60% when the trinary switch off the AC triggers it.
Here are a few pics of the install:
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 06-04-2005, 07:16 AM   #17
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Is this the pic your thinking of? This is what happened to the stainless steel flex fan on my truck. I was driving it at about 50 mph when it happened. It sounded like a boulder landed on my roof and then the truck started shaking like all heck, felt like I was riding on 4 flats. (out of balance fan after losing a blade)
Just glad I wasn't poking my head under the hood revving the engine when that happened.
BTW, that didn't just go through the flat steel, it also went through the under hood reinforcement! I had to remove it with a hammer!
This fan was on my truck when I bought it but I sure won't use anymore! They should be pulled from every shelf.
Anyone that is using one of these, I suggest you take it off now and throw it away.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-04-2005, 10:50 AM   #18
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Hey Bob. my uncle's 78 4x4 has the exact same hole in the hood!! Now you could gold plate a flex fan and he would throw it in the trash. I would never run a flex fan on anything. They are cheaply made and as you can see, are prone to disassembling themselves at any time. ...............Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 06-04-2005, 12:26 PM   #19
Mongo
YES_____NO
Mongo's Avatar
Yep that be the one
Old 06-04-2005, 06:12 PM   #20
71Dragtruck
71Dragtruck's Avatar
Would love to see some pics of this setup, I have very limited space and this is the only dual setup I've seen that will fit. A little more CFM would be nice.
71Dragtruck is offline   Reply With Quote
Old 06-05-2005, 05:17 PM   #21
chickenwing
Thanks 72RestoRod. I was indeed scratching my head on this install. I had no clue what to do. Trashed my brackets also. Was courious what others had done. Never occured to me to make a bracket like yours. Looks nice. Figure mine came out ok. I had some stainless sheet layin around I had snagged from a scrap pile. I installed a some threadserts into the radiator core supports, cut 2 rectangles out of the sheet and was in business. Tucked in real nice under the radiator cover I got from LMC.
Oh if anyone trys what I did... Make sure you use a drill stop.
Old 06-05-2005, 11:39 PM   #22
4x4Poet
Originally Posted by pat
... Then there is the stock fan....
If you meant a 6 blade fan, chipflyer is right about the 7-blade fan's superiority to all mech fans:
Originally Posted by chipflyer
...I replaced the flex fan with a new clutch and the original 7 blade fan and it was much better. Last week I replaced the 3 core radiator with a new 4 core and now the temp needle just comes up a little bit regardless of weather its warm outside or the A/C is on....
This seven-blade fan, whether stock or off another GM vehicle, is the ticket for anyone who doesn't mind the small hp loss with mech fans. It really pulls good air when properly shrouded and with a new fan clutch (~$40) that will last 100k plus, trouble-free miles. I hate the electric setups since I never want to gain a little extra hp for the track (or extra fun). With all due respect to our drag racers and general go-fast folks, the stock fan clutch with a 7-blade, GM fan and 4-core radiator all cools better than most folks need while towing uphill in the hottest part of the country. So it boils down to whatchya want: Just economical, uncomplicated, good cooling or expensive, complicated, good cooling +extra hp.
The 7-blade costs $100 new at the stealership, but used ones can be found in wrecking yards on many GM cars and trucks. If you go used, have it magnafluxed to check for cracks and be sure to find out the cost of doing so before you pay the wrecking yard too much where a new one would be easier, prettier, and sure. Classic Industries sells the 7-blade GM fan for $100 but they do have 10% or 20% off sales now and then. Not my favorite vendor, though (to say the least).
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 06-05-2005, 11:51 PM   #23
Mudder
Mudder's Avatar
At the time I went electric the guy at Jegs told me the Perma Cool metal blade fan would move the most air. The on I got is rated at 2950cfm's. Works great and have used it going on 3 summers here in MO. I have one of Wes' shrouds for a single fan.
Mudder is offline   Reply With Quote
Old 06-06-2005, 05:52 AM   #24
GMC AMI
GMC AMI's Avatar
Electric fans are cheap and plentyful at the junk yards. We always put them on drag cars with no overheating problems. I use one on my 656 hydro tractor for extra cooling
while making hay when the sun shines, gets a lot of strange looks!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 06-09-2005, 09:23 PM   #25
mocwon
Keep On Truckin'
mocwon's Avatar
Pictures of installed electric fan
1" square tubing top and bottom with socket nead screws through the radiator top and bottom supports. Shortened mounting brackets to work. I still need to take it back apart to paint it.
Just Passin' Thru
