PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed ![]() ![]() |
#2 | |
Keep On Truckin'
I haven't bolted mine up yet, but am using a third brake/cargo light off a 94 Chevy truck on my 72. It requires modification (cutting) the back of the cab. It's going to be tight but it'll work. Here's a picture of the hole in the cab. For some reason the picture won't upload
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... Last edited by mocwon; 06-03-2005 at 03:54 PM. |
Has anyone done the LED brake light conversion?
71 rustless in texas
www.Superbrightled.com has led lights that will fit in the regular socket and are quite bright. Thats what I have. I then just tapped into the brake switch wire and it works great.
Sorry should be www.superbrightleds.com
![]() Join Date: Mar 2001
I have the one from earlyclassic...tiz expensive, but it fits perfectly and works. Only thing, I think it should be "glass coated/sealed" to keep the elements from attacking the traces. This wont happen overnight, but will over time. I started pricing out LEDs that are bright enough for the application, and they start to add up quickly, plus you still need to make a pcb (printed circuit board) So all said and done, the earlyclassic version is a quality piece. I hooked up the brake switch to the 3rd brake part of it, and the door switch to the cargo light part of it, so it operates like a new truck.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
