SWB 4X4 CLUB
Another header question
Hi all. I have looked in the FAQ's and could not find a section on what headers fit our trucks. Could someone tell me what headers wil fit (including part numbers) without mods to the frame or anything else.
I have a 1968: 350, 4X4, 4speed on the floor. This would make for a good topic in the FAQ section. Thanks in advance Jason |
The LuvShack Garage
HMMM, 4 spd eh, I went this route, I deceided on which header company
I wanted to run, then I called them up from my cell (Most peeps have free long distance) and let them do the leg work, I went through SUMMIT and JEG'S, got 4 different part numbers, and only one of them fits. my $.02 ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() Join Date: Mar 2001
Anybody use the ones "earlyclassic" sells? Item #11-6572HDRS to fit the smallblock.
Kinda pricey, but they come ceramic coated.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
jay_shy: Since you have the 4x4, the engine sit back enough that you may want to consider covette manifolds, they have a 2-1/2 center dump. Not a header though.
SWB 4X4 CLUB
ttt
I am totaly confused on this subject also. It seems every time I look, there are several different part numbers for the same application ( K-20) and I have only looked at the Hedmans at this point because the local exhaust guy said they are the best to clear and tuck above crossmember on passenger sid for ground clearance.
A good confirmed part number ( ceramic or not ) would go a long way on this subject to assure something that will fit and work, especialy when you shell out the bucks for ceramic............well worth it from all standpoints I have been told! |
First off make sure you let them know they are going on a MANUAL truck.
I ended up putting some Heddmen headers on my 67 swb 327 2wd 4 speed manual. The headers need to clear the Clutch pivot arm that connects from your engine to the frame. I had to cut, reposition, and weld up my pivot arm just for the headers to fit. I would suggest long block huggers instead of the shorty block huggers, a set of custom stainless steel headers, or if you want to go balls out, stainless steel Tri-y's that fit. Wrap em up with header wraps and sh!t boi, you be readys to roll. Fah nah nahnah Dont be afraid to drop the coin on some stainless steel babies, trust me they are worth it, they will never rust up on you. -The Red Rooster |
SWB 4X4 CLUB
you can't tell me that no one has put after market headers on our trucks.
Anyway, if you have I am still looking for a set that fits with a part number, and where you got them from. hopefully someone has made this mod. looking forward to your input, Jason |
#9 | |
~Rest In Peace~
check this ad out for the headers
see the dynotech headers ad 115001flt 89.00 bucks ![]() ![]()
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
I recall someone saying Hooker SuperComps fit their manual 4wd.It is a hard thing to find a definative answer on.I`m with you.The header companies or at least dealers are vague,and most just want to sell something.Once you get them,you`ll make them work or pay to send back.
70 blown GMC, Sounds like you are on to something from dynatech, but I couldn't find em on that ad.
Any help? ![]() |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I have also heard of chevelle header's fitting just to add to your confusion....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#13 |
ttt
#14 | |
~Rest In Peace~
wolfthing click on the bottom of the page
#15 |
Nothings as cool as my 72
Does anyone know if those edelbrock ti-tech headers are anygood. I don't want chrome because they discolor.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. ![]() |
#16 |
Active Member
I just put a set of ceramic coated Hooker Competitions on my Blazer (Summit part # HOK-2453-1HKR). I did have to alter the Z-bar to fit even though they said that they are compatible with 4-speed. It's an easy alteration.
![]() The previous owner used a slightly different method to get z-bar clearance ![]() ![]() |
