06-03-2005, 09:53 PM | #1 |
Psalm 23
Question about stroker engines
I've been seeing alot of "Stroker" engine threads lately. Honestly I have not a clue what qualifies an engine as a "stroker"...could someone please explain this to me.
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy |
06-03-2005, 09:58 PM | #2 |
senior member
it has to do with the stroke you piston travels. attained by a new crank shaft. someone please correct me or add to this if im wrong
69 GMC bagged |
06-03-2005, 10:15 PM | #3 | |
YES_____NO
or is it longer arms with shorter pistons. Now I am confused
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
06-03-2005, 10:25 PM | #4 |
Suburbans RULE!
The term generally refers to engines that have strokes longer than originally equipped. For example, the 388 in my Burb. Originally, it was a 350 with a 3.48" stroke. I rebuilt the engine and used a different crankshaft that had a 3.75" stroke. Generally new pistons are required as well.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
06-03-2005, 10:32 PM | #5 |
its all about the +6 inches
Adding stroke...that defines stroker.
Many common ones, 383 being top of the list. (for chevy motors anyways) |
06-03-2005, 11:11 PM | #6 |
A way to look at it ( or 2) is to imagine a bycicle with pedal arms ( distance from center of pedal sprocket to center of pedal attatchment point) that has , say, a 8" length and it is a little difficult to get up a hill. So you increase that length by 2" it is now easier to get up the hill because you have increased the torque ( what a stroker motor does) More leverage!
Or , you can't quite break loose a large nut from your output yoke on your transmission with your regular length breaker bar no matter how hard it is you pull. You slip a length of pipe ( cheater) over the breaker bar and increase your handle length and it becomes easy to loosen the nut. More torque. These reasons are why a stroker motor is a great towing or puller engine. They whip your head back off the line too! Wolfthing |
06-04-2005, 01:14 AM | #7 |
Psalm 23
Oh alright...awesome, thanks for explaining that guys.
