Old 06-04-2005, 04:04 AM   #1
ZmOz
Tire pressure?
I'm sure this has been talked about before, but the search is....
What tire pressure should I be running in my '79 C20? The manual is MIA and the sticker on the door is unreadable. Tires are stock size, with 16.5" wheels. Right now they're at about 25 PSI, that can't be helping the mileage.
ZmOz is offline   Reply With Quote
Old 06-04-2005, 05:35 AM   #2
ureckme
ureckmefixit2@cox.net
It should say on the tires
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 06-04-2005, 06:35 AM   #3
Ogier
Chopper/Painter
Ogier's Avatar
Exclamation
Tire pressure, the right way.
Step one: Weigh your vehicle. You need to know how much weight is actually on the front axle and the back axle seperately.
For the sake of example, lets say it is 2500# on the front and 1500# on the rear.
Step two: look at the pressure rating of your tires. They will say something like "Max load 2500# at 35psi"
With this in mind, two of the tires are capable of carrying 5000# max at 35psi in the tires.
Step three: Take your Max load and divide it by your actual loads.
I.E. Front tires are 2500# / 5000# which comes to .5 or 50% of the total load.
Rear tires are 1500# / 5000# which comes to .3 or 30% of the total load.
Finally, multiply the max tire pressure by the percentage that you figured out.
In this example, Front psi = .5 * 35psi = 17.5psi
Rear psi = .3 * 35psi = 10.5psi
This is probably not right for your truck as I don't have your truck's weights. However, the method is correct. I usually won't run a 35# tire under 25# though. I have done my tires this way for years and don't burn the centers out of them or have premature failure unless some kind of foriegn body is involved. I.E. nail.
The nice thing about setting your tire pressures correctly is that no matter what you drive, you will get a nice ride out of it.
Please note: If you talk to your "Tire Professional" at your local tire shop, they will tell you that this is wrong. This is because they truely don't know any better.
Just my .02$ whatever it may be worth.
With regards,
Ogier
1969 Chevrolet C20 - Resto-Custom started!!!
Ogier is offline   Reply With Quote
Old 06-04-2005, 10:21 AM   #4
eagle23
Active Member
The correct answer imo is 'it depends'
If you don't carry much in the truck, I'd probably use 32 in front, and maybe 28 in the back. If you do carry a lot, use pressures closer to the max. The sidewall markings are really only good for max loads. The 'tire professionals' will always inflate them to the max: they aren't liable for anything going wrong if the tires are inflated to kidney-jarring pressures.
I just checked my owners manual on my '77 C10 just for grins...not a straight answer to be found, just a lot of pages of it depends/don't overinflate/don't underinflate/etc.
One indicator is the treadwear pattern. Is anything showing up? And what kinds of loads do you carry how often?
eagle23 is offline   Reply With Quote
