06-04-2005, 10:39 AM | #1 |
BlahBlahBlah
i need this for 4x4 rear end
ok im not sure what these are called. i have a 71 half ton 4x4 that has the under axel mount for the ubolts to pass through and hold axle assembly to springs. my ubolts are for the other style. the one that sits on top of the spring assembly and the u part of the ubolt goes around the axel not the spring. so i need either a set of ubolts that are squared off to go over the springs or i need the upper style mount and i can use my current rounded ubolts (they are new). i would prefer the upper style mount assembly. i thought i saw what may be those in one of tee's pictures. thanks and i hope i described this correctly.
06-04-2005, 10:57 AM | #2 |
Just like to part out trucks!!
The square ones are the original ones, I have the ubolts and original plates for $40 plus shipping. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
06-04-2005, 11:11 AM | #3 |
BlahBlahBlah
if the squared off ubolts are original those are the plates i already have. they mount under the axel. and the ubolts i have are wrong. would you happen to have a set of the mounts that go on top of the springs?
06-04-2005, 11:24 AM | #4 |
I'll have to look when I go out there. Thanks
06-04-2005, 11:26 AM | #5 |
BlahBlahBlah
thanks tee..if you have them i'll take em.
06-04-2005, 12:43 PM | #6 |
Here are the only ones I got out there
06-04-2005, 02:29 PM | #7 |
BlahBlahBlah
i loaned my camera out so i cant get a pic to show you exactly what im looking for. when i get it back i can take a shot. i believe its the same one that is used on the front axel. thanks for taking the time to look for me.
06-04-2005, 02:42 PM | #8 |
u-bolts
If Randy can't help you, this is what I have. I'm not sure it is what you need, but it was out of a 72 rear leaf spring truck with a 14B full floater fitted to it. The U fits under the axle and the plate goes above the springs.
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
06-04-2005, 08:59 PM | #9 |
BlahBlahBlah
thanks for the help and the pm's guys. today when i was working on the truck i was looking in my "junk" pile and found a upper mount set in there. i have no idea where they came from. amazing how much stuff you accumulate when you have these trucks.
