~Rest In Peace~
making my own battery cables
what size gauge should i use for the pos + and neg - cables and for the alt. wire ?
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
I used 2/0 gauge welding lead for my battery cables and 8 gauge for the alternator wire. It works good for me. I have a 120 amp alternator.
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
![]() Join Date: Mar 2003
Damn----2/0 for the cables, pretty beefy. I use 2 guage, has been plenty for my trucks and a little easier to work with. Definately 8 ga. on anything close to 100a alt.
Active Member
![]() Join Date: Jun 2002
2/0 is a good size for battery cables, actual wire size is about 0.36" or just under 3/8".
2 gage is about 1/4" and should work for most trucks. What you have to look at is what you are running, high compression, hard turning engine you want as much juice as you can get to the starter. Agree 8 gage good size for alternator should most anything you put on your truck. It is not what your alternator puts out but how amps your electrical system draws that determines wire size. Hence dead shorts melt wire = large amp draw.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
A 2 guage cable is closer to 3/8 wire diameter. Works good on my tow trucks for everything
