06-04-2005, 01:00 PM | #1 |
Stepsides RULE
Gas Gauge Problem
I know this has been addressed in the past, but i couldn't find it, so. My gas gauge is reading too full. On the last tank, it read waay past full, and when it just got to E i was almost out. Usually it goes a little past E. On this tank, i've put around 50 miles on it, and the needle has barely moved.
So my basic question is: Is the ground bad or is the gauge headed south? Or even worse, is it something on the sending unit? Thanks in advance, cliff
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
06-04-2005, 02:32 PM | #2 |
Tonawanda 454
on my 76 when i fill it up it goes about 1/4 tank past F then i can tell it runs on fumes as soon as it starts to touch the E... i just never worried much about it, just keep track of miles or fill it up at 1/4 tank each time....
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
06-05-2005, 03:52 AM | #3 |
06-06-2005, 10:04 PM | #4 |
Mark
this may sound strange but check all grounds esp the wire from block to fire wall and ground under dash but if ya need a nother 1 i got one in the garage
Look at every day as a holiday, some just better than others.Build what you got be happy with what you have This truck is for sale |
06-07-2005, 01:17 AM | #5 |
Professional Grade
Yeah, if your sending unit is fried, I've got a spare one sitting up here that you can have for 10 bucks + shipping. Worked perfectly in my GMC. GMC had one of the bigger tanks that was available on these trucks. I am not sure if there is a difference despite length.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
