06-04-2005, 04:25 PM | #1 |
93 Suburban Misfire question...What Next?
I posted a while back looking for advice on which 91
or older Sub to buy. After lots of local searching I've decided that I won't find exactly what I want. Well, that and my wife has really pushed for the newer body style of the 92 and newer versions. Ok, there are a lot more of those available within a few hundred miles of me anyway. What I want is a 3/4 ton with 4wd and a 454. I found what appeared to be the best deal around here in a 93. It has 130K miles on it but 34K miles ago the original owner had a dealership put a new GM replacement motor in it and had the transfer case rebuilt. When I looked at it it was in pretty good condition inside and out with a few exceptions. The shocks are worn-- about $350 installed for new shocks. The steering is loose--Anywhere from $150 to $1000 with alignment depending on if it's really simple or if it needs new everything. The deal-breaker is that the engine has a misfire at idle. Not really bad but bad enough that it wouldn't pass California smog. The seller and I agreed that if he could make it pass smog and get rid of the misfire I'd buy it for $5300. That was almost $2000 cheaper than anything else I found with 115K miles or more and none of the others had the newer motor. The seller has had it in a shop for a few days and the mechanic sounds like an idiot who's just throwing parts at the problem. So far he's replaced the EGR, the Prom chip, O2 sensors, Distributer, Plugs and wires and both fuel injectors. It still has a misfire. Now the mechanic says he's going to try replacing some/all of the plug wires again. Huh? He's several hours away from me so all of this is coming from the ignorant seller. I won't buy it with the misfire. My next guess would be possibly a burned valve but I'm no mechanic so that's just a guess. I don't know if the mechanic has performed a leak-down test. Obviously he should. The seller is just about at the limit of what he will fix to sell this to me. Monday the new wires go in but I'm not optimistic. The upper limit of what I will spend, (on something this old) is $8000. I can't imagine what else could cause this misfire at idle but I doubt that if I had to pay for it myself it would exceed my upper price limit. But I just don't want to buy something with a mysterious engine problem. Ok, so if this deal doesn't work out I'm done looking for something with this many miles, new engine or not. I have avoided the 96 to 99 Vortec engine because I've read a few reviews that indicate that even though they're more powerful, they also have quite a few more problems and they're a few thousand dollars more, at least for anything with under 100K miles. My next question is just how do the Vortec Subs with a 454 compare in reliability to the throttle body injected 92 to 95 Subs? I know they have intake manifold coolant leak problems. What else? If I spent $10K or $12K on a 96 to 99 with 60K to 90K miles would I really be getting a much better Sub or would I be spending a lot more for a nicer dash and lots more headaches? I can't afford more than $12K right now and even that is pretty much spending everything I got. There wouldn't be anything left for possible repairs or upgrades. Any advice from the list? Thanks for any help. One last note, because of a severe knee injury that's not going to be better for a long, long time, I'm very limited to what I can repair myself. My best friend owns his own shop and will give me a big break on parts and labor but nothing is free... Bruce Redding, California |
06-04-2005, 09:58 PM | #2 |
Tonawanda 454
If you weren't so far I would sell my 91 R2500 4x2 to you for $3200.
Two things to try, fuel filter... Other thing to try that was notorious for these burbs is the whole distributor rod assembly all the way down to the gear. They tend to wear at a specific range of RPMs that it is used the most during its life. If it idled more than anything in its lifetime then it does it at idle.. The rest of the range usually runs great with maybe slight hesitations at shifting. Mine has this same problem from 47-57 mph. Right now I'm at work work so much and so much to do around home that I dont have the chance to do it so I will suffer for a few weeks. I have also replaced the spark plugs, wires, dist cap and rotor, fuel filter and had injectors checked. I would also tell the owner to get a 2nd and 3rd opinion. I may be wrong but this is my 2¢. My burb:
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- Last edited by screwballl; 06-04-2005 at 10:00 PM. |
06-05-2005, 03:13 PM | #3 | |
Thanks for the reply. I don't know if the fuel filter
has been replaced/checked or not since I'm about a 3 hour drive away. But I will suggest it to him. He says it now has a new distributer but who knows? Of course, before/if I hand over any cash I will require all recent receipts. I couldn't get written confirmation on the new motor 34K ago because of some GM dealer privacy policy but I did speak to the service manager at the dealership and he gave me the info over the phone. I guess he could've lied but I doubt that he would bother for someone he didn't know. He was pretty specific. Thanks again and if anyone else has any answers to any of my questions I would really appreciate an answer. Bruce Redding, California Quote:
