BlahBlahBlah
big nut, anyone know the size?
not the correct picture, but this same bolt on a chev 12 bolt rear. this is the nut that holds the rear yoke in place.
no brain no headache
i think it MAY be 1 1/8 i cant remember though
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() |
![]() Join Date: Mar 2001
1-1/8 is correct
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
BlahBlahBlah
i found this info about 10 bolt rear...it says the bolt is 1 1/4. these big sockets are pricey i just wanna make sure 1 1/8 is correct. thanks for the input guys.
http://www.fullsizechevy.com/fscu/axletech/ |
Mike
Buy a quallity socket.A lot of the cheap ones are to thick to fit.They make them thicker to make up for useing a cheaper alloy.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Junior Member
I will measure mine when I get home tonight.
72 GMC 3/4 ton Custom Camper 5.3 ltr 4l60e 72 Chevy Blazer 4x4 327 4spd 70 Olds Cutlass supreme 455 4spd m21 |
It's a catastrophic success.
![]() Join Date: Jan 2003
No more than they are needed the cheeper ones will get you through.
http://www.harborfreight.com/cpi/cta...temnumber=3994 |
Mike
The problem I had with a cheap socket,it was to thick,and would not fit in the recess of the yoke to tighten the nut.The socket bottom out before the nut was set.The guy whose place I was at,had a no name set.I had to go home and get my sk set.
Young Gun wth Fast Inline
What you are talking about is the pinion nut. Get a good one as it can be a bear to get off sometimes.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! Last edited by stelth2002; 06-06-2005 at 03:35 PM. |
Junior Member
I must not have the original nut on mine as it is 33 millimeters. Just 1.25 mm more than a inch and a quarter.
Project92 SWB stepside
MY 10 BOLT 8.5 WAS A 1 1/8TH. Autozone has em for around $4 for a single.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
The one I bought was too thick (ACE) so I ground it down to fit. I check it every day to make sure it is still in my tool box...
Bob 68 C20 Camper Special |
#13 |
Check the local pawn shops, down here in Tacoma you can get a Craftsman socket from the odds & ends bucket of sockets for about 2-3 bucks. Great way to fill out a tool set for things you don't always use very often.
