Old 06-06-2005, 02:21 AM   #1
AesC10s
Chevy truck addict
AesC10s's Avatar
Question New guy for bags
Im new to the bagged suspension i have a 64 half ton longbed that i would like to bag. i dont want it to Lay rocker i would like it to sit about an inch from the ground. Since i dont know to much about gettin all of the right parts needed and what mods i have to do to my frame, so would you guys PLEASE help me out here so i get a good set up and a great end result.
this is a great board and thanks for all of the help in advance, Aaron
AesC10s is offline   Reply With Quote
Old 06-06-2005, 03:15 AM   #2
'84 Rusterado
'84 Rusterado's Avatar
bump for a felow newbie, i would like to know as well...
'84 Rusterado is offline   Reply With Quote
Old 06-06-2005, 01:26 PM   #3
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Well the hardest part is going to be Zing the frame. It is neccessary to lay frame. You could do a crossmember drop but from what I have gathered it is easier to just Z it.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 06-06-2005, 01:27 PM   #4
fastbagged68
fastbagged68's Avatar
first things first! What size tire you plan on running....overall height? That will let you know what you will have to do to get it to sit where you want it to!
fastbagged68 is offline   Reply With Quote
Old 06-06-2005, 03:17 PM   #5
XXL
Seņor Member
XXL's Avatar
OP mentioned he doesn't want it sitting on the frame.
XXL is offline   Reply With Quote
Old 06-06-2005, 05:44 PM   #6
bagged69c10
I thought he said he didnt want it on the rocker, he wanted it an inch off the ground. I took it that he wanted the rocker an inch of the ground which would be laying frame.
1965 c-10 long bed
1993 Sierra x-cab
Old 06-06-2005, 06:29 PM   #7
AesC10s
Chevy truck addict
AesC10s's Avatar
My rockers hang like an inch lower than the frame on my 64. I will be running a 28 inch high tire.
Old 06-06-2005, 06:56 PM   #8
fastbagged68
If you are running a 28inch tall tire in the front and keeping your wheel wells uncut then it won't be an inch off the ground! On my 63 suburban my body sits about 1/2" off the ground and I have about 3-4 inches of tire sticking through my wheel well. If you don't want to cut I recommend running a 18inch rim with 245-40-18. That will get you 2 inchs lower with out cutting the wheel well. You will need drop spindles. Switch out your ball joints to 73-88 and run 3 inch drop spindles. If you want to see pics let me know.
Old 06-06-2005, 08:03 PM   #9
AesC10s
Chevy truck addict
AesC10s's Avatar
Im getting rid of what ever stops me from gettin it an inch off the ground. Yes i would like to see picture pics help alot.
Thanks Aaron
Old 06-07-2005, 12:04 PM   #10
AesC10s
Chevy truck addict
AesC10s's Avatar
What size air tank an compressor do i need? im gonna be gettin slam spec rs72's for bags.
Old 06-07-2005, 12:41 PM   #11
fastbagged68
I'm running 2 - 5 gallon tanks with 4 1/2" ports on each with a Engine driven compressor. You make the call. Are you going to play alot?
Old 06-07-2005, 04:32 PM   #12
AesC10s
Chevy truck addict
AesC10s's Avatar
of course im gonna play around alot im a 17 yr old kid. lol I was thinking of an 8 gal. tank with 8 1/2" ports and for a compressor i was thinkin of useing a Viair 380 200 psi compressor becuase i dont have the $$ to spend on an engine driven system. Im gonna be running 3/8 lines and valves but im not sure what valves i need and how many. could you help me out on that one? Thanks for all of the help, Aaron
Old 06-07-2005, 05:02 PM   #13
fastbagged68
Since you are going to play....get more air. Run like 2 6gallons or 2 5 gallons. Save your money and buy a engine driven compressor. Or go to a junk yard and pull a york off of a old ford or volvo. You could probably pick up one for under $50. And if you are going to play with it get 4- 1/2" valves. Run 1/2 line! SMC/Parker valves are probably one of thebest valves out. If I were you i would buy a 4 link and either get F9000 and mount over the axel or mount some double convulated bags in a 2:1 ratio. You need to crossmember drop your front, run 3 inch drop spindles.
Old 06-07-2005, 05:12 PM   #14
AesC10s
Chevy truck addict
AesC10s's Avatar
How do i hook up the york and around what year ford do i get it off of? Im going to z the frame not drop the crossmember.
Old 06-07-2005, 05:20 PM   #15
AesC10s
Chevy truck addict
AesC10s's Avatar
Oh and id rather not do a four link.
Old 06-07-2005, 06:06 PM   #16
AesC10s
Chevy truck addict
AesC10s's Avatar
Also What valves do i use for airing up and what valves do i use for dumping and how many of each. I dont wanna go side to side or anything special i just wanna go up and down with the rear and front.
Old 06-07-2005, 06:15 PM   #17
fastbagged68
The york compressor you can get from I beleive 70's ford trucks. Check out www.pirate4x4.com I think that is it. or ask slammed67 on this board! As for valves run 8 valves... 4 1/2" up and 4 3/8" dumps. This will give you the ablity to go side to side but you can wire it up to lift the whole front. Do not run front and back with only 2 valves each. the truck will lean and will handle poorly. You will have to get 3 inch blocks for the rear and do some fabbing to get your truck down on a 28" tall tire.
Old 06-07-2005, 06:49 PM   #18
AesC10s
Chevy truck addict
AesC10s's Avatar
Ok I was planning on the 3" blocks and im doing a 10" Bridge step notch from suicide doors. What other fabbing will i have to do? so on the valve i do one 1/2 fill and 1 3/8 dump at each bag and do i put them in any speical order? How do i set the valves up right? Do you have any diagrams for the lines and wires of how to set it up? I really apprechate the help man, Aaron
Old 06-07-2005, 07:28 PM   #19
fastbagged68
Aaron do a search on here for the diagrams there is one some where on this board. Valves you do as you said. Inlet to 1/2" valves to T fitting, then your 3/8" dump valve, on the other end of the T run to your bag! Before you order that bridge kit make sure your trailing arm is not going to hit your frame when laid out. Take your rear spring out and look at where the trailing arm will cross up with the frame. Make sense?
Old 06-07-2005, 07:36 PM   #20
AesC10s
Chevy truck addict
AesC10s's Avatar
Im going to be goin with a watts set up form speed way motors.
Old 06-07-2005, 07:46 PM   #21
fastbagged68
No not the panhard bar, your trailing arm might hit your frame.
Old 06-07-2005, 08:28 PM   #22
AesC10s
Chevy truck addict
AesC10s's Avatar
Oh well if it hits i will put in a notch for the arm to sit into.
Old 06-07-2005, 08:44 PM   #23
AesC10s
Chevy truck addict
AesC10s's Avatar
Ive been looking at valves and i dont have any clue what valves to get for what and im just getting confused. Could you tell me What ones you are using and or which ones i should get.
Old 06-07-2005, 10:17 PM   #24
AesC10s
Chevy truck addict
AesC10s's Avatar
Never mind i found what valves i need.
Old 06-10-2005, 12:07 AM   #25
71swb4x4
71swb4x4's Avatar
I bought my valves from ***************** When I first was shopping I heard nothing but good things about them. I think they are gong through some growing pains right now and service is a bit slow, but prices are pretty good!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
