replacement weatherstripping?
Any low cost alternative to door weatherstripping? I need to replace a piece on a truck I'm selling, but don't want to put another 50.00 from Year One into this truck.....I'll be lucky to get out what I've already put into it, but its a pretty nice truck, but the door weatherstripping is missing altogether....The paint shop couldn't get it off w/out ruining it because someone had glued it in previously.
TIA!!
69 chevy SWB 70 GTO 65 GTO hardtop 65 GTO ragtop 77 Trans Am Hmmm. Too many pontiacs, not enough chevy trucks yet. |
67-72 Addict!
S-10 truck/Blazer weatherstrip is soooo much nicer than the factory glue on type!. It's heavier duty and it presses in place so you can remove it (for a paint job) then reinstall it. The 71' I am working on had this installed by the former owner and I'm sold on it now. There have been alot of posts about it. It's always available at the junkyard if you are on a really tight budget.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Psalm 23
I'm interested in this also.
Will any year S-10 weatherstripping work? Also is it more or less expensive than ordering exact replacement weatherstripping for our trucks from Year One, LMC, Summit or other such companies. Thanks
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy |
'68 C-20 396 CST CC
![]() Join Date: Mar 2005
Check out this link...I haven't tried it yet but I'm going to...
http://67-72chevytrucks.com/vboard/s....php3?t=122688
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES ![]() 01 Jetta Turbo Daily Driver ![]() 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico ![]() |
Blue 67
![]() Join Date: Apr 2004
I put a set few weeks ago, fitted right on. The problem since then is that door shut very hard. It seems it needs some break in period but in exchange when they are shut you don't hear any noise from outside. I got mine from gmpauls around 60 some dollars. The actuall old fashion ones are around 40-50$ I believe. gmpauls ahs all both version.
Hey! Thanks for the response! That should work perfect for this!
![]() Join Date: Jan 2000
I also used the S-10 weather stripping. It was so much easier to install. I got mine from Wes.
hey Steven B-
How did you finish the ends that are exposed when you take your top off? |
The weather stripping was for my pickup. The weather stripping on my Blazer is the original replacement. Glue and clamps.
