Old 06-06-2005, 05:01 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
truck no starty
strange kind of deal. it acts just like your trying to start the truck in other than d or n. before you jump on the neutral safety switch, already checked it out. still nota.
i tried jumping the starter, not much happens. barely a spark. yes the battery is fine, the cable is ok. the head lites come on bright.
un guessing it the starter, but i never seen one this dead before. any ideas?
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 06-06-2005, 05:57 PM   #2
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
Does the solenoi make any noise? Can you hear the bendix clicking?
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 06-06-2005, 06:05 PM   #3
That is what I am thinking. Many a solenoid gave out on me. I know I use to cheat them alot, by cleaning the contacts in the soleoid and the tube that slides in the solenoid (forgot its offical name). I would then rotate the tube a bit so it slides and contacts on a fresh clean surface. It kept me going in my youth (when I was broke) or when I lived in Japan and couldn't run down to a local auto parts for a replacement.
Palf70Step is online now   Reply With Quote
Old 06-06-2005, 06:13 PM   #4
mtdave2
mtdave2's Avatar
ya, i think thats it too.. no click, not anything. just a small spark when you try to cross it. ill put in a starter tomorrow, its the original starter, so its proably due.
69 k10 Suburban
Old 06-07-2005, 11:55 AM   #5
mtdave2
mtdave2's Avatar
never seen a starter THAT dead. i climbed under the truck and listend when someone turned the key. all i heard was a slight hummm sound.
i replaced the starter, and started right up. strange to go from no problems to that dead in one start.
as a side note, it is kinda cool to have a truck that is orginal, i just changed the orginal starter..lol not bad, 30 some years it sat on that engine.
69 k10 Suburban
Old 06-07-2005, 05:29 PM   #6
boogie67
boogie67's Avatar
dead starter
It was probably your starter brushes.I had the same problem thats what it was.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 06-07-2005, 08:18 PM   #7
mr402
If you want to keep it original some shops will rebuild your starter for you. Don't do the exchange thing. Glad to see you get it running though.
Enjoying life again. Time to get those big blocks rolling.
mr402 is offline   Reply With Quote
Old 06-07-2005, 08:34 PM   #8
mtdave2
mtdave2's Avatar
a bit late there bro. i did think about that when i was turning it in. but i have not had much luck rebuilding starters and alts. everytime i do it, i wish i had done the 39.99 lifetime warentee thing....
the truck is now back in its bed, im happy, trucks happy...=)
69 k10 Suburban
