Old 06-07-2005, 12:10 AM   #1
skokie
skokie's Avatar
Intake Manifold Install
Ok I am putting the intake back on and need to know how long to let the rtv beads sit before dropping the intake on it? I thought it was 20 mins? Anyone?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 06-07-2005, 12:15 AM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
rvt hi temp
i install it right away making sure that it gets a good seal around while its wet
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-07-2005, 12:20 AM   #3
knsmodels
I make Models
knsmodels's Avatar
Same here...right away.
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 06-07-2005, 07:14 PM   #4
Pilgrim
Same here...it worked well.
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 06-08-2005, 01:23 AM   #5
skokie
skokie's Avatar
UPDATE!!
Tonight I finished putting on the carb, dizzy,hooking the booster back up stuff like that. Havnet started it up yet ran outta time again tonight I did manage to get all the plug wires run neater than before so thats a plus. If all goes well tomorrow night I will start it up and post back.
68 build thread
Old 06-08-2005, 01:33 AM   #6
Ogier
Chopper/Painter
Ogier's Avatar
RTV and all the other silly-cone sealants suck for engine building!
I don't use them and I don't recommend using them.
With regards,
Ogier
1969 Chevrolet C20 - Resto-Custom started!!!
Ogier is offline   Reply With Quote
Old 06-08-2005, 01:59 AM   #7
fastwillie 696969
~Rest In Peace~
rvt hi temp
to each his own
i know i got to use it on my on a blower motor you cant use the end gaskets on the intake you got to use rvt because of the pressure so if a blower can be use with just rvt and seal it then rvt is fine
then there times i used just the gaskets and gaskgoo (tacky glue )
Old 06-08-2005, 12:49 PM   #8
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I'm a believer in RTV.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 06-08-2005, 12:57 PM   #9
'70_402
'70_402's Avatar
I disagree. Like was said earlier. To each his own
'70_402 is offline   Reply With Quote
Old 06-08-2005, 01:19 PM   #10
speedracer
Blank
speedracer's Avatar
I use "The Right Stuff" it works great
speedracer is offline   Reply With Quote
