WORTHLESS CRUISERS
spindle question
I have a 69 Chevy with 2 1/2 drop spindles. Im using the same size tire combo I had before I switched to 5 lug. Also same wheel offset. The spindles Im using are from CPP. Now my tires stick out further than I would like. What spindles do I need to tuck the tires in a little more? Or are there other alternatives?
Scott Hammond Lancaster, SC 1969 Chevy ![]() If you don't live for something, then you'll die for nothing. www.xclusive-images.com ![]() |
Epoxy Primer Friendly
You could shorten the control arms. While they are out you could also Z the lower balljoint for more drop.
I believe you want DJM Spindles. I know Bell Techs push wheel out 1/4" or so.
laying low
![]() Join Date: Mar 2001
I don't know first hand but have heard some dropped spindles increase the track width by 3/4" per side. I wouldn't like that either.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
I used early classic spindal on my 72 and no problems. Call Dave up at early classics, he can set you up.
