Old 06-07-2005, 01:50 PM   #1
86 GMG
door window question
this is just a question that came up in a discusion with some friends of minethe other day while drinking beer in the shop after hours, anyway are there diffrent thicknesses of door glass between the 77 to 82 and 83 to 87 it seems to me as a kid i had heard this. from what i can tell they will all interchange but one while fit tight in the side tracks and is hard on the regulators please any help will be appreciated, there is a beer purchase for the guys riding on this. and trust me i dont want to have to pay that!!!!!
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 06-07-2005, 02:12 PM   #2
60-66 Nut
Professional Beer Tester
I think the change in the glass thickness came with the front end change in 1981, in order to help lighten the trucks up a bit. Do I get a beer if I'm right?
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 06-07-2005, 02:53 PM   #3
86 GMG
yeah sure but it will be pretty darn hot before i get it to you so will this work for you instead
Old 06-07-2005, 06:13 PM   #4
60-66 Nut
Thanks! Even the thought of a cold beer is better than nothing!
60-66 Nut
85 GMC Short Bed
86 GMC Short Bed
92 GMC 1500
Old 06-10-2005, 10:52 AM   #5
DrPepper
Did I miss the answer to the glass thickness question?? The answer could explain why some guys don't like power windows. If the glass is too thick for the tracks, the window motor will have a hard time pushing the window glass. Again, does anyone know if there really are different thickness door glass??
DrPepper is offline   Reply With Quote
Old 06-10-2005, 01:52 PM   #6
bodydropped
only glass difference i know is the back ones they made a thick and then style
bodydropped is offline   Reply With Quote
Old 06-10-2005, 03:22 PM   #7
86 GMG
dr pepper: enless the windows have been changed the glass and track were corasponding
bodydropped: i really dont know this to be a fact yet but 60-66nut maid a good point that makes since if you have any factual info please let me know thanks 86 gmg
Old 06-10-2005, 05:03 PM   #8
bodydropped
they did make 2 different ones because my 78 had a then one and i bought a thick one since i wanted a none tinted one but i ended up buyin another thick one not sure what years they came in but my 82 had a thin one with a 1 peice gasket and i have a 77 at work with a 1 peice and it was thick but my 78 has the 2 peice and it is thin and as for door regulators im runnin a regulator out of a 78 with 83 door glasses and havent had a problem with them
Old 06-11-2005, 12:13 AM   #9
f.monroe
f.monroe's Avatar
Thickness .
There are two different thicknesses . I think it was in 81 when they went to a thinner side glass . They also changed the vent glass . The later trucks with the thinner glass has a shorter vent glass by about 3/4 to 1 inch . If you look at the top of the vent glass rubber seal you will be able to see the difference . They arent that much different but if you have one of each ,you can really feel the difference . Frank
f.monroe is offline   Reply With Quote
Old 06-14-2005, 11:24 AM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The door glass and vent glass changed in 1981. There are also different rear glass thickness.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-21-2005, 09:21 AM   #11
86 GMG
sorry to bring this back up but i have come to realize that when i changed the wing window in my truck it was from an older truck it bolted in just fine no problems or major adjusting do you thing this is why the window dont roll up and down correctly?
my truck is an 86 and the wing window is like a 77 or so
Old 06-21-2005, 11:00 AM   #12
Slonaker
Insert Witty Text Here
Slonaker's Avatar
My '86 has a vent ("wing") window in it from a truck from the 1970s. The only difference I noticed was there was one less mouning point. My window works fine.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-22-2005, 09:27 AM   #13
86 GMG
One Less Mounting Point I Dont Remimber That, Thanks I Guess I Just Dont Have It Adjusted Correctly
Old 06-22-2005, 10:07 AM   #14
Slonaker
Slonaker's Avatar
Mine used one less screw than the original. There was a mounting point near the top hinge that took a screw through the edge of the door. The 70s style wing window did not have a place for that screw.
Slonaker
Stock '01 Silverado
