Old 06-08-2005, 02:18 AM   #1
muddpile
muddpile's Avatar
Custom Door Panels??
I was just wondering if anyone here has ever considered buying/building custom door panels for their 67-72? At the moment I have the stock plastic 72 door panels, but the style is pretty dated and I always bash my knuckles on them when trying to roll the window down.
I was thinking of buying the Roddoors dano door panels, but then I thought that I could likely build my own custom ones for much cheaper and have something truely unique. Has anyone ever tried this, and if so, what material did you use for the base of the panel and how thick was it. I've seen everything from wood to cardboard used, so I suppose almost anything would work. Also, how would a guy go about attaching it to the door? Epoxy the clips to the back of the new panel? I have my design all planned out with Orange tweed and white vinyl, but I still need to bring it into reality.
muddpile is offline   Reply With Quote
Old 06-08-2005, 09:42 AM   #2
mocwon
Keep On Truckin'
mocwon's Avatar
Billet aluminum inserts machined to replace tin foil, woodgrained, factory inserts. Rod Doors headliner covered in fabric.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-08-2005, 10:36 AM   #3
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Hey Mocwon, have you got a pic of the headliner? ..........Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 06-08-2005, 04:22 PM   #4
hgs_notes
GEARHEAD
hgs_notes's Avatar
This link was posted a while back, I came across it again on a yahoo search for "custom door panel"
custom door panel how to
HG
hgs_notes is offline   Reply With Quote
Old 06-08-2005, 04:27 PM   #5
'70_402
'70_402's Avatar
Hey Muddpile Did You Ever Get Those Kick Panel Speaker Enclosures Built? If So Are You Selling Them?
'70_402 is offline   Reply With Quote
Old 06-08-2005, 08:04 PM   #6
jt67
Registered Car Nut
jt67's Avatar
Ive got custom doorpanels made, Ill try to get a pic soon.
jt67 is offline   Reply With Quote
Old 06-08-2005, 08:08 PM   #7
muddpile
muddpile's Avatar
Thanks for the help guys! The "How To" with the grey tweed is more the idea I'm going for, but I'll likely be using a combo of vinyl and tweed instead, plus adding an armrest of some sort.
And 70 402, got the wood backing traced out so far for kicks and that's been about it. I was going to start progress on them, but my car needed brakes and exhaust. Within the next couple of weeks I may do a bit more work to them. I haven't decided whether or not I'll make a few pair and sell them, but I've got all the diagrams and stuff if I do, so I guess I'll see how the first set goes and then decide from there. I'll make a post and let everyone know if I do.
Old 06-09-2005, 09:07 AM   #8
GreyHoundSteve
I had custom door panels built out of fiberglass and covered them in leather. No pics yet because they are in a pile at the back of the shop with all the other finished interior peices but i think they turned out pretty well.
GreyHoundSteve is offline   Reply With Quote
Old 06-09-2005, 08:22 PM   #9
modifiedGMC
Heres mine. I took the factory panel and added the arm rest, and handle to open with from a 79 caddy. I also used the power windows and door locks from the caddy and mounted the switches in the arm rest where they were in the caddy. The flames were embroidered on.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 06-09-2005, 09:27 PM   #10
mocwon
Keep On Truckin'
mocwon's Avatar
Dano headliner picture
Here it is but the pictures didn't turn out too good...
Just Passin' Thru
