Old 06-08-2005, 02:34 AM   #1
Smallz72project
Smallz72project's Avatar
Question Short Coil?
Try and post this again since I didnt get much help last time, but thanks for posting responses to those of you that did. I am wondering if GM ever made any swb trucks with the coil suspension with the control arms. I have a 70 Chevy lwb with the coil set up with controls that go from the axle to the crossmember where the carrier bearing is positioned. What I am wanting to do if possible, is cut the frame and modify the suspension to make it a swb. Any help is greatly appreciated, I'm a bit new to the customizing of trucks, so hang in there with me.
Smallz72project is offline   Reply With Quote
Old 06-08-2005, 08:46 AM   #2
smokekiki
Mike
smokekiki's Avatar
I am assuming by Your board name that You have a 72? Yes, most of these trucks had coils.The arms and coils are the same,swb or lwb.Here is a thread on cutting the frame. http://67-72chevytrucks.com/vboard/s....php3?t=123624
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 06-08-2005, 01:10 PM   #3
Smallz72project
Thank you for you help smokekiki, that is exactly the information I was looking for. Yes I have a 72, but it has leafs on the rear, I recently accuired a 70 lwb with the coils, and I plan on swaping the frames. Thanks again
