Old 06-08-2005, 09:16 AM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Question Battery mounting question
Has anyone mounted their battery on the driver's side? If so, what did you use for a battery tray? I considering it since the alternator is on that side of the serpentine setup.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-08-2005, 10:18 AM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
I've never seen a battery mounted on the driver's side. I don't see why you couldn't just remove the battery box and bolt it on the driver's side. Something to think about though, unless you have a pontiac or similar motor your starter is on the pass. side, right? That's a long way to route that thick starter wire.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-08-2005, 10:33 AM   #3
kwmech
I have the factory dual battery set-up (TP2) in 2 of my trucks. The option usually came with the camper special package. You will have to run a really long batt cable to reach to your starter.
Old 06-08-2005, 01:09 PM   #4
NPilot1975
NPilot1975's Avatar
MOCWON-
I used a stainless drop-down battery box from CPP and mounted it behind the cab on the frame of the passenger's side. It works great and you don't even know it's there, plus it cleans up the engine comartment.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 06-08-2005, 01:26 PM   #5
mocwon
Keep On Truckin'
mocwon's Avatar
Yeah, I've seen that and like the looks of it.
Originally Posted by NPilot1975
MOCWON-
Just Passin' Thru
Old 06-08-2005, 07:29 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you have a chevy engine in there still, i would not do this mod. The long positive cable is a bad idea. You are better off with a long charge wire instead of a long starter wire.
however, as stated, if you have a pontiac or Caddy motor, then it will be benificial to do this, and you can get the Aux battery tray on the parts board from time to time...post a WTB (want to buy) thread. Normally they seem to go for the $50 neighborhood.
Old 06-09-2005, 09:34 PM   #7
mocwon
Keep On Truckin'
mocwon's Avatar
It's a Chevy but I don't understand why the long positive cable is a bad idea. I've done it several times on cars when puting the battery in the trunk and this is a lot closer than that. What problems will this cause?
Just Passin' Thru
Old 06-10-2005, 12:29 AM   #8
Edmond
Edmond's Avatar
My starter battery is also on the driver side and have no problems with starting the engine.
I have put in a 50mm2 cable to the starter
(Have no idea what that is in AWG, but the cable is thick, like a welding cable)
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 06-10-2005, 02:21 AM   #9
Americanrider
I agree with Longhorn Man. It's a little thing called resistance, which builds up heat. Think of it this way: It takes energy to push energy and expended energy equals heat. Did you ever try to push 30 amps through 18ga wire, it gets real HOT!!! The longer the cable the more drain you have on the cranking amps. If your running a top of the line battery and large cables it should be fine. Larger cables will have less resistance through them. The older/weaker the battery + smaller the cables = trouble. As far as the battery tray issue, there are some nice stainless steel ones on e-bay for about $19+shipping out of Vancouver WA. Not for the purest truck builder I understand but then you have a serp belt anyway.
Americanrider is offline   Reply With Quote
Old 06-10-2005, 07:09 AM   #10
mocwon
Keep On Truckin'
mocwon's Avatar
I'd run a larger cable for sure. It's pretty easy to figure the size of cable required for the amp draw. I thought there was something else here I might be missing.
Just Passin' Thru
Old 06-10-2005, 08:51 PM   #11
Longhorn Man
Your point about the relocated to the trunk batteries is a very good point, and I'll reduce my comment to...
Make sure you use the right guage and route the cable to where it won't get pinched.
