Old 06-08-2005, 11:47 AM   #1
jtminton
II Timothy 4:2
jtminton's Avatar
Temp gauge question
I am having a problem with my temp gauge, and was hoping somebody can help. When I turn on the key, the needle pegs to the right. It moves so fast, you can hear it click on the peg when it does.
Here is a picture with the key off:
This is what happens when I turn on the key:
I have a new sender, and the wire from the sender to the firewall looks good. I pulled the dash and made sure the nuts on the circuit board thing were tight, but it didn't do any good.
Suggestions what to check next?
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline   Reply With Quote
Old 06-08-2005, 11:50 AM   #2
jhow66
jhow66's Avatar
Does it return to the left if you remove wire from sender with switch on?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-08-2005, 11:58 AM   #3
jtminton
II Timothy 4:2
jtminton's Avatar
I'll have to check that when I get home. It's sunny, so I rode the bike today. If it does, what would that indicate?
Old 06-08-2005, 12:20 PM   #4
pjmoreland
pjmoreland's Avatar
Sounds like the green wire that connects to the sender is shorted out somewhere.
pjmoreland is offline   Reply With Quote
Old 06-08-2005, 12:36 PM   #5
67chevemall
67chevemall's Avatar
ya the green wire is pinched or cut open onto metal somewhere.
Just follow it to the sensor or replace it.
67chevemall is offline   Reply With Quote
Old 06-08-2005, 12:39 PM   #6
jhow66
jhow66's Avatar
Old 06-08-2005, 01:52 PM   #7
mtdave2
newly minted old timer
mtdave2's Avatar
i had the same thing happen to my truck. i ended up replacing the gauge. first time it did it i about had a heart attach. driving on the highway at 70, look down and the temp was pegged. i turned the truck off and pulled over. i thought something was strange, usualy when something overheats like that, there is a smell,,you all know im sure...
i popped the hood and looked. everythign was fine. so i figured it was the gauge. freaked me out though!
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 06-08-2005, 04:37 PM   #8
wolfthing2000
My truck is doing same and I twiddled around with wire and it worked good for awhile. I found a good front harness at wreck yard. Will replace all. Wolfthing
wolfthing2000 is offline   Reply With Quote
Old 06-08-2005, 05:56 PM   #9
A.P.
Black 72 Chevy
A.P.'s Avatar
jhow66 I had this same problem when I installed a new sender, it was the wrong one. Use an ohm meter and measure the resistance between sensor and ground. On my truck it now measures open with the engine cool. As the engine warms up, the resistance drops.
Good luck.
A.P. is offline   Reply With Quote
Old 06-10-2005, 03:47 PM   #10
jacill
I have about the same problem with mine. I checked and made sure that the wire was good and bought a brand new gauge and sending unit. My wire goes into the fuse box is that correct? If it is then I think my circuit board is bad. That is about all it can be isn't it. Don't mean to infringe on your post just trying to get more ideas out there.
jacill is offline   Reply With Quote
Old 06-10-2005, 04:11 PM   #11
jtminton
II Timothy 4:2
jtminton's Avatar
No problem! I do it all the time!
Hey, does anybody know if you are looking at the back of the gauge, which post (left or right) the power hooks up to, and which one the sender hooks up to? I was thinking of just running my own wire straight from the sender.
