06-08-2005, 12:01 PM | #1 |
Senoir Member
need help with a/c compressor & hoses.
I need to buy a compressor for our 85 K10 with 350...compressor missing....I get 2 choices for the new one, electric plug at 9 or 12 o'clock position. Which one is correct for the 85 truck. Pictures of the a/c lines, drier, compressor plug & mounting would be greatly appreciated.
Thanks, Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
06-08-2005, 12:57 PM | #2 |
Insert Witty Text Here
My '86 has the plug at the 9 o'clock position, if that helps any.
FYI, everytbody I know has problems with the $100 rebuilt compressors. They last about one summer, sometimes two if you are lucky. I bought a NEW R4 locally for $220 or $240, I don't remember exactly. Depending on what you plan to do with the truck, it might be worth the investment. You might also consider buying a Sanden and the appropriate brackets. A friend (who designed the Vintage Air system for our trucks), runs a Sanden on his V8 S10 and says it puts less of a load on the engine. I think Alan Grove sells a sanden bracket. If you need any specific pics, please let me know. I know Kevin Shortell has some pics of his '86. I have seen him post them before. Slonaker |
06-08-2005, 04:53 PM | #3 |
Senoir Member
Thanks for the info. I could use pictures of how the compressor brackets mount, and a picture or 2 of the hoses/ drier. I need to find most of these items to install on ours. Greg
06-08-2005, 05:19 PM | #4 |
If you don't have what you need in the next day or two, PM me. I am at work, and will probably forget by the time I get home.
I have some photos of the A/C brackets that I took when I removed/cleaned/painted mine. I'll have to take new photos of the hoses and drier. Slonaker |
06-09-2005, 12:07 AM | #5 |
Some of these shouold be helpful...
http://slonaker.net/images/truck/gregbr/ I'll leave them up until you tell me you got them, but please save them to your hard drive so I can pull them down. (Right click image, "save picture as..."). These have been resized. I can provide larger copies if needed. Slonaker |
06-09-2005, 09:32 AM | #6 |
Semper Paratus |
06-09-2005, 09:33 AM | #7 |
P.S. I'm going to have to get around to taking a new photo under the hood. I've cleaned it up a bit already- new plug wires, coolant hoses, etc.
Semper Paratus |
06-09-2005, 09:34 AM | #8 |
Senoir Member
Thanks Slonaker!! Those pics of the brackets are GREAT, they will help alot. Thanks also to Kshortell. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 Last edited by gregbr; 06-09-2005 at 09:37 AM. |
06-09-2005, 10:51 AM | #9 |
I'm glad they helped. I thought they might. I took them so that I could remember how to put the brackets back on.
Slonaker |
