Complete Tpi System
COMPLETE TPI SYSTEM
I have a complete TPI unti off a 350 sbc on ebay. http://cgi.ebay.com/ebaymotors/ws/eBayI … 7979838994 Good luck |
DAMN, I love Big Blocks!
TPI E-bay Link
There....fixed your dead link for you. ![]() Pictures might help you sell it. Just a suggestion.
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. ![]() Last edited by 76HighSierra; 06-08-2005 at 09:58 PM. |
87 suburban "Jack"
What would I need to do to install this on my 87 suburban? It currently has a TBI unit on it. Would I need a new computer? and if so do where do I find one for my application? I must assume the same questions apply for a wiring hahness.
Bump
Damn Skippy ![]() |
you would need a wiring harness and comp. harnesses can come from painless, howell performance etc. as for a comp you would need to get one from a yard, ebay etc
87 suburban "Jack"
thanks
Damn Skippy ![]() |
didnt sell on ebay
250 anyone interested?? |
Slots go on anything!
what is that off of?
1974 Jimmy- 5.3/4L80e/NP241 |
#8 | |
No No
F-bodys and Vetts were stuck with them. Need a fuel pump too if you buy/use it, 13 PSI TBI pressure isnt going to cut it. ![]()
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
yeah, I knew that. The 90-92 units were Speed density vs. Mass air flow for teh 85-89 units. 85-88 had a cold start injector, and thus different runners and base. The SD intakes used a different plenum casting as well, with a place to mount the MAP sensor on the right side. 350's used different injector that the 305's as well.
Sorry, I looked at the picture a little closer and it looks like an early system, with the cold start injector.
1974 Jimmy- 5.3/4L80e/NP241 Last edited by Jonboy; 06-15-2005 at 10:20 PM. |
