Old 06-08-2005, 02:12 PM   #1
mike63078
Complete Tpi System
I have a complete TPI unti off a 350 sbc on ebay.
http://cgi.ebay.com/ebaymotors/ws/eBayI … 7979838994
Good luck
mike63078 is offline   Reply With Quote
Old 06-08-2005, 02:32 PM   #2
Jason915
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7979838994
your link didn't work for me, you may want to add what year it is from as there were some minor changes through the TPI years ie: mass air/SD set ups.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 06-08-2005, 04:29 PM   #3
vtblazer
vtblazer's Avatar
What, no pics?
vtblazer is offline   Reply With Quote
Old 06-08-2005, 04:41 PM   #4
hilljob26
hilljob26's Avatar
is that the setup w/the cone type filter sticking out the front of the throttle body
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 06-08-2005, 07:02 PM   #5
mike63078
you are correct i have a pic in anyones interested
Old 06-08-2005, 07:06 PM   #6
Russell
Professional Grade
Russell's Avatar
Pics always help a ton with selling stuff -- If you need help posting a pic here, email it to me and I will post it for you (Zieglerdigital(at)hotmail.com)
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-08-2005, 07:38 PM   #7
71swb4x4
71swb4x4's Avatar
Anymore information? Year and mass air or speed density would be great.
hilljob26, you are refering to the speed density system. You can run an air filter right off the throttle body, on the mass air you have the mass air flow sensor between the filter and the throttle body.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-08-2005, 08:19 PM   #8
mike63078
this is a mas air system (which is much more forgiving one a upgraded motor).
comes with everything you need and will accept early heads or centerbolt heads.
real nice setup it for you rloking to upgrade your truck to a reliable efi system
Old 06-08-2005, 08:24 PM   #9
mike63078
heres a pic
Old 06-08-2005, 09:40 PM   #10
71swb4x4
71swb4x4's Avatar
Wow, that looks really nice. Do you have any other pictures?
Old 06-08-2005, 09:50 PM   #11
incoma
incoma's Avatar
Does it include the wiring harness, dizzy, and pcm? What about the sensors? Maybe I should look at the ebay auction too!!
incoma is offline   Reply With Quote
Old 06-08-2005, 10:24 PM   #12
jmanz69
Careful, they attack...
jmanz69's Avatar
As far as wire harness PCM and sensors go, I would get a megasquirt stand alone and run it that way. The wire harness would be much easier, and you can program it yourself. That is what I planned on doing to my TPI for my 327. The MS system is like $300 or so. That is a nice looking TPI, I assume oyu cleaned and inspected everything.
jmanz69 is offline   Reply With Quote
Old 06-09-2005, 09:07 AM   #13
Chevy Muscle
< 69 Blazer
Chevy Muscle's Avatar
Nice unit.... I'm guessing that shipping is Free???
Chevy Muscle is offline   Reply With Quote
Old 06-09-2005, 10:08 AM   #14
boraxman
Keepin an eye out
boraxman's Avatar
Im surprised no ones bought it yet
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 06-09-2005, 10:19 AM   #15
mocwon
Keep On Truckin'
mocwon's Avatar
Looks to be a pre-89 unit since it appears to have the cold-start injector runner.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-09-2005, 04:10 PM   #16
CHEVYE
my gas saver
CHEVYE's Avatar
good deal, i had a complete setup, wiring cpu and all. it sold last year for $750 on ebay. i got the bid going a bit for ya.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 06-09-2005, 04:37 PM   #17
hilljob26
hilljob26's Avatar
so it will bolt right up to the older 350's,pre 84,mine is out of a 73,it will work...huh...i might have to do something about this
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 06-09-2005, 04:46 PM   #18
'70_402
'70_402's Avatar
I Agree With The Others You Would Get More Money For It On Ebay If You Posted A Picture In Your Ebay Ad.
'70_402 is offline   Reply With Quote
Old 06-09-2005, 05:01 PM   #19
CHEVYE
my gas saver
CHEVYE's Avatar
usually the only mod needed is to elongate the mid intake holes a bit so they line up and thread into the heads on older style engines. other than that it should bolt right up and go all the way back to the old 50's small blocks.
71`SWB, project
ebay feedback
