WTB Crane Springs for stock heads
Got a killer deal on a comp cams 292 H want to get a set of Crane Hot Springs the kind that need no machining of the stock spring seats to use with this cam I believe rated for gross lift of .510 anyone have a set let me know with shipping to business 43758 thanks Mike
hav'n fun be'n me ![]() |
![]() Join Date: Feb 2004
springs
I got a set of comp cams triple springs good for up to .600 lift they are only about 3 months old they still have the yellow paint on them you can have them for 40.00 shipped to your house I will also include the steel retainers and locks too let me know. I dont know if you would have to machiene them to fit a small block they fit bb with out machiening ( they will work for both bb and sm chevy I do know that much I dont know the exact od but i can take a tape out there and give you a rough estimate if you want. there virtualy brand new. for what you save in springs even if you had to machiene the heads you would come out on top, take a look in jegs or summit on the comp triple springs
springs
thanks alot for the reply but the motor is together and I am just gonna switch cam etc and not pull the heads so I really need to stick with stock on the bottom diameter spring thanks again Mike
