Old 06-08-2005, 10:57 PM   #1
rage'nrat638
rage'nrat638's Avatar
69 failed emission's test......
350 with 600 holley.......
not much to adjust......
any thoughts......thanks mark ......running rich....
rage'nrat638 is offline   Reply With Quote
Old 06-08-2005, 11:33 PM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
Have you tried the new power adder listed here? Emmissions legal power
I've tested it and if you can get a flourescent marker, it helps emmissions also.
HG
hgs_notes is offline   Reply With Quote
Old 06-09-2005, 12:00 AM   #3
Tim240Z
Tim240Z's Avatar
10% mix of denatured alcohol in the tank has saved me everytime.....available at any hardware or Home Depot store. Otherwise, basic tuneup and check ignition timing, and idle speed.
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 06-09-2005, 12:03 AM   #4
FirstGen
Just Don't Stop!
FirstGen's Avatar
wow, in Texas, vehicles older than 21 years old don't have to be emissions tested only safty inspection...
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 06-09-2005, 12:07 AM   #5
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
75 and newer here have to test, and no inspection. you could weld some cats in there
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 06-09-2005, 12:23 AM   #6
cdowns
cdowns's Avatar
no inspections of any kind for any year in florida
Old 06-09-2005, 03:03 AM   #7
rwgregory
I don't believe my eyes!! Some other state is actually more screwed-up than
California??? In the illustrious "Golden State" anything '73 or older is SMOG EXEMPT!!
rwgregory
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 06-09-2005, 03:10 AM   #8
71Longbed
Not Mine But A beauty
71Longbed's Avatar
its 76 n up here
68 Chevy Shortbed 454/400
2000 Chevrolet Camaro SS 6spd
2011 Silverado 5.3 6spd auto
71Longbed is offline   Reply With Quote
Old 06-09-2005, 04:10 AM   #9
Super Duck
Chevy Nuttttt
Super Duck's Avatar
lean out the jets, retard the timing, and lean out the idle mixture screws. That wit hthe alcohol and you wil pass. or just move to a state that has no emitions on older stuff.
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 06-09-2005, 09:09 AM   #10
Canadian72GMC
Everything the other guys said, and you might find this odd, but change the engine oil immediately before you go back to be retested. If it was close to passing, that alone could get you by.
Canadian72GMC is offline   Reply With Quote
Old 06-09-2005, 10:10 AM   #11
Lemield
Lemield's Avatar
rwgregory
In Colorado, anything 1960 or older is emission exempt IF you put collector license plates on it. Anything 25 years old or older....back to 1960 must pass ONE emission test IF you are putting collector plates on it. The collector plates are good for 5 years and (so far) they don't make you get retested.
If you want to run regular Colorado plates, you have to have it tested EVERY YEAR regardless of the age of the vehicle.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 06-09-2005, 10:23 AM   #12
CHEVYE
my gas saver
CHEVYE's Avatar
when i lived in nashville metro they made us do emissions. my Z28 wouldn't pass one time, so i went and bought one of those "prolong" engine treatment kits. i went through after dumping that stuff in and it passed. now i'm out of the metro area and we don't inspect any year vehicles for anything, hell they'll let you ride around with no fenders and doors out here.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 06-09-2005, 10:35 AM   #13
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
No suggestions not listed. I am courious though, what emissions equipment was on a 69? Heat stove and a pvc valve right? No EGR or any other junk?
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 06-09-2005, 10:47 AM   #14
Tim240Z
Tim240Z's Avatar
rwgregory
Actually, now it is fixed (ie no rolling exemption) at 1976 and older are exempt from testing, although are required to maintain all applicable emissions control equipment. CHP and BAR have been setting up roadside test stations again lately.
1972 Suburban C20
Old 06-09-2005, 01:06 PM   #15
tomatocity
tomatocity's Avatar
What are the readings? Look at them and see where you failed. It could be a carburator adjustment. Lean is good.
-Change the oil and filter (get that old polluted oil out of your engine.
-New air cleaner
-New fuel filter
-Run a can of Pass Smog by CRC found in most parts stores, Walmart, etc. (this stuff works) I learned this from a technician that repairs vehicles that have failed emissions testing
-Check for and repair any vacuum leaks
-Check the timing with and without vacuum advance (less is good)
-New spark plugs, wires, cap, rotor. Check your old spark plugs for color. They should be a light choclate color
-Make sure the engine is thoroughly warmed up.
-Make sure the technician does not raise and lower the RPM's quickly. This dumps excessive fuel into the system
-And anything else the other members suggested
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 06-09-2005, 01:08 PM   #16
tomatocity
tomatocity's Avatar
One other thing. Move to California. Emissions testing starts at 1976.
Old 06-09-2005, 03:10 PM   #17
ChebyCheyenne
ChebyCheyenne's Avatar
In Washington, emissions testing isn't required fro anything 1980 or older or something like that. I have a 67 & 72 truck and a 91 Jeep, so anything in between that im not sure on, correct me if im wrong.
matt
Truck #1:
1972 Chevrolet K20 Cheyenne Custom Camper
SB400, TH400, NP205
Truck #2
1967 Chevrolet C10 Custom Sport Truck
327 small journal, TH400
ChebyCheyenne is offline   Reply With Quote
Old 06-09-2005, 06:55 PM   #18
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
My '70 doesn't require emissions testing here in St. Louis County. Just a Safety inspection. I'd hate to have to get it tested!
'92 GMC Sierra, Sportside, 2wd, 350, Black
'92 Chevy Silverado Extended Cab 4 x 4, Blue
USAFR = 2A674 = Aircraft Fuel Systems Maintenance
i.e. Tank Rat
TsgtE662 is offline   Reply With Quote
Old 06-10-2005, 08:09 AM   #19
Bowtie67
Bowtie67's Avatar
A couple of things,
I have seen multiple holleys with cracked metering bodies leaking fuel and running excessively rich, Power Valve blown or incorect will also cause rich running, they also now have power valve blowout kits available and would higly recomend one of these to anyone running the older holleys, the older holleys all it would take to blowout the power valve was for the engine to backfire back through the carb.
In recent on my truck I had swapped out the cam to something a little bit more radical, prior to the cam swap I didnt notice any real richness but after the new cam it was pretty bad, I decided to try the pure Acetone treatment that someone else had posted a while back because of some minor pinging with 93 octane and octane booster was $10 bucks a bottle. Use 2-3 ounces to 10 gallons of gas, it quit the pinging and I didnt have anywhere near the fuel richness from the exhaust, I also noticed a slight improvement in gas milage. You can buy quarts of pure Acetone at Home Depot for $6
http://pesn.com/2005/03/17/6900069_Acetone/
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 06-11-2005, 10:28 AM   #20
rage'nrat638
i think i am going to put a two barrel carb on this thing......
if that don't work i will......have buy a toyota....NOT
Old 06-11-2005, 10:38 AM   #21
jhwkns
Registered Cruiser
jhwkns's Avatar
Mark; Mine wont pass at idle unless I set it at 1100-1200 rpm. If you're rich at idle you could give this a try. Here in Nevada the idle speed can go as high as 1250 during a test. G/L
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 06-11-2005, 04:15 PM   #22
I can`t believe some states make older vehicles go through emmisions.They are such a small percentage of the total vehicles on the road.And,even fewer daily drivers.My`99 ZR2 has both cats fryed.I punched-out the little egg-shaped one in the y-pipe($700 part)and Meineke replaced the rear one.It melted down and clogged the exhaust in two weeks.That got punched out.If it doesn`t pass next time(probably will),I`ll test it with an almost empty tank and racing(maqic juice)fuel.She`ll be burning real clean!
Old 06-13-2005, 10:59 PM   #23
rage'nrat638
well i kicked there butts......
i install a two barrel carb..rochester......
cut the co from 90 the limit to 46
the richness from 1475 to 86......
and you know what if runs great,,,,,,,
passed like a champ......just a fyi.....
removed the holley 600.......
think i am going to stick with the two barrel.......going to check mileage....
i bet it go's up....... ne:
Old 06-26-2005, 04:36 PM   #24
69chevytruck
69chevytruck's Avatar
Move to Arkansas, there is no inspection what so ever and you only need three pieces of paper to register your truck, one is the last registration.
my 69 has an inline six and it has pcv and a an AIR pump as emmison control components.
1969 C-10,short bed, I6 250, 3x1 offy, HEI, headers, 5 speed, original paint and family owned!
69chevytruck is offline   Reply With Quote
Old 06-26-2005, 04:50 PM   #25
greenhorn male
greenhorn male's Avatar
I heard it was fixed @ 1975 and older in CA, exempt.
03 Tahoe
72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays.
greenhorn male is offline   Reply With Quote
