Old 06-09-2005, 01:14 AM   #1
iluvmy72
how do I fix....had wreck
OK.......I had a wreck last year and now my truck has just been sitting there. I think I have some frame damage. My truck hit another truck hard with it's ball hitch sticking strait out. It literally bent my bumper into a "V" on one side. I could see that where the bumper is mounted the arms are bent. Is this the fram. And am I hosed on this frame? Ifr So I'm going to find a rolling chassis and start over.
iluvmy72 is offline   Reply With Quote
Old 06-09-2005, 07:43 AM   #2
JimKshortstep4x4
Talking
Good frame shops can do a lot on frames. If only one frame horn is bent, it might be worth checking out the cost of straightening it. I would suggest having someone with frame experience look at it.
Jim
Old 06-09-2005, 07:57 AM   #3
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
i rear ended another trucks trailer hitch pretty hard . I broke my engine mounts andmy motor slip forward and burst the radiator then the driveshaft fell out. I removed the bumper. I had to replace the bumperand the arms that hold the bumper. the only place my frame was bent was the small holes at the very front that bolt directly into the bumper.
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 06-10-2005, 12:06 PM   #4
iluvmy72
I'm thinking I just ned to find a whole new chassis. If I can find a SB rolling chassis with a bed, that would be cool.
Old 06-10-2005, 12:31 PM   #5
Green Machine
Green Machine's Avatar
I'm wondering if the "arm" that is bent is just the bumper mounting bracket, as you say it was hit more to one side. Bumper brace is easy to replace. It takes a pretty hard hit to bend the actual frame, and unless the frame is really hosed, it can be bent back a little if needed. If you could get some pics that would help. If you could remove the bumper and take some pics that would be even better.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-10-2005, 02:19 PM   #6
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
You are in Cali, I don't think people can even give these truck away over there, much less a rolling chassis.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
