06-09-2005, 10:16 AM | #1 |
4x4 help, transfer case works, hubs don't
Hi;
As you can tell by my other posts, I am currently certifying a 1983 Chev Blazer 4x4 305ci The 4x4 doesn't work. It has limited slip on front and rear. The guy I bought the truck from (for $400) said that 4x4 worked, but when I jacked it up to investigate, I found that: The transfer case engages no problem. However, the front wheels don't turn in 4x4. I would imagine that this is a problem within the hubs. Wondering if any of you can specifically mention which part may be broken that would stop the wheels from powering. I have the service manual, but I want to research these problems before I start taking the hubs apart. Thanks Last edited by Dr.Destructo; 06-09-2005 at 10:17 AM. |
06-09-2005, 11:33 AM | #2 |
user # 2756
Do you see the u-joints turning in the axles?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
06-09-2005, 05:04 PM | #3 |
Yes
06-09-2005, 06:14 PM | #4 |
Then if you locked the hubs and the wheels don't turn, you need new hubs.
Open them up and see what's going on inside.
72 GMC K20, 454, TH350 00 GMC Yukon 66 Ford Bronco |
06-09-2005, 08:37 PM | #5 |
user # 2756
ditto
06-10-2005, 12:25 AM | #6 |
Are those the GM Auto hubs?, if they are just junk em now and buy some warn premiums
06-10-2005, 01:53 AM | #7 |
Thanks guys. I asked this question on a few boards, so I got the same answer everywhere. Looks like new hubs are in order. Going to open them up this wknd...thanks again.
06-10-2005, 08:31 AM | #8 |
Mike
Like kwmech said.Put a set of manual hubs on.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
06-10-2005, 10:38 AM | #9 |
Chevys Kick A$$
Get you a good set of Warn manual locking hubs.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
