06-09-2005, 01:33 PM | #1 |
Edelbrock 1406 problems??
I have a 70 chevy 4x4 with a built 350. Nothing crazy just an rv cam, aluminum intake and it is bored .030 over. I am running 4.10 gears with a 350 turbo tranny. The truck seems to run alright when there is no load, but as soon as I hook up to my 19' camp trailer and it has no low end pulling power. When I go up hills I can smell it running rich. Would the carb have that much effect on the power? What kind of setup are you guys running with the 1406. Any ideas would be great. Thanks
06-09-2005, 01:53 PM | #2 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
06-09-2005, 02:59 PM | #3 |
When I moved from California to Colorado a few years ago, the altitude change of 6000 feet totally messed up the perfomance of my carburetor. I spent a lot of time playing with the metering rods, jets and metering rod springs to get the carburetor back to normal. I would suggest getting your hands on the owner's manual for your carburetor. It contains a lot of helpful information on how to select the correct combination of jets, metering rods and springs.
06-09-2005, 03:05 PM | #4 |
I will check all of those things out. I live about 3200 feet, and when I go to the mountains at around 6000 to 8000 feet it really runs like crap. What should I jet it for in those conditions to get the best all around performance. Thanks
06-09-2005, 03:14 PM | #5 |
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
06-09-2005, 03:36 PM | #6 |
Lovin' Life in Miss.!
Welcome to the board! I am no tuning guru and have had my share of 1406 woes. http://67-72chevytrucks.com/vboard/s....php3?t=127083 This is a good link for carb spacers (helped me out a lot): http://67-72chevytrucks.com/vboard/s....php3?t=122462 There was another really good one about the spacers but could not find it.
The truck... you hear that? No really, you did hear that?!!! |
06-09-2005, 04:25 PM | #7 |
Not trying to hyjack post but my truck has a lean problem part to full throttle. What should I change to solve?JACILL i'm runnin a 1406 5" tall air cleaner carbspacer to addapt to spreadbore intake 355 with compcams 280H flat top pistons 3.73 rear. I got most of the stumble out of mine but now it goes real lean at 4500rpms. So lean its like it floats the valves. I think I need to go up two sizes but I'm no carb guy.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
06-09-2005, 04:41 PM | #8 |
There's a graph in that 1406 manual that shows what combinations of jets and metering rods to use based on what change you want to see. There are also some suggestions in there for high altitude. If I remember correctly, I used setup #24 on the 1406 chart for 6000 ft, and it works great. Of course if I ever go down in altitude, I get a bunch of valve knock. Personally I would recommend tuning the carburetor for the lowest altitude you drive at on a regular basis.
06-09-2005, 05:25 PM | #9 |
computer illiterate
check your timing i had that problem when i pulled my trailer timing was off
72 2wd blazer 72 swb 4x4 |
06-09-2005, 06:46 PM | #10 |
Carbs tend to run richer as altitude increases, Might want to wean it out a bit, maybe leave the fat part of the rod alone and fatten up the skinny end as that is the power or enrichment end that you may be using when pulling hills. JMHO.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
06-09-2005, 11:07 PM | #11 |
Your UncleBen
Guys guys guys....3 words...Fuel Pressure Regulator. With the Edelbrock carbs you HAVE to run a FPR with them. Unlike holley/q-jet carbs that like 6-8 psi fuel pressure, Edelbrock carbs only like 4-5 psi. Trust me on this. You will be suprised what a difference it will make. Probably solve most of the problems that you guys are having with the Edelbrock carbs.
lata CHRIS
68 C10 shortbed -- Street/Strip Last edited by SweetandLong68; 06-09-2005 at 11:08 PM. |
06-09-2005, 11:28 PM | #12 |
The 1406 manual recommends using the Edelbrock #8190 fuel pressure regulator if the pressure is over 6 psi. I think I'll get one of these. Unfortunately it costs about $50 for one.
06-09-2005, 11:48 PM | #13 |
I agree that is required. Had one from the get go.
My problems were mainly fuel contamination, and a spread bore wood spacer, that caused major vacume leaks. Pitched the contaminated tank and got a phenolic 4-hole 2"spacer. Most of my problems went away. Only thing left is a slight stumble on part throttle acceration. I've went this long... I'll get to it. I had a suggestion of going to a stronger step-up spring and/or moving the pump linkage. I might try the linkage since I can SEE it. The springs.... I'm scared I'll screw something up.
06-10-2005, 12:05 AM | #14 |
I agree with Meathead, check your timing first. My 72 was freshly built, with new carb other goodies and it ran great and sounded Bad A$$. But when I hooked up to my tiltbed trailer it would slow to a crawl going up a hill. After chasing a supposed carb problem it turned out to be the dizzy all along. AAaaarrggghh.
Nik |
06-10-2005, 01:33 AM | #15 |
I have checked the timing and it is about 10 degrees. It wouldn't change with a heavier load on it would it? I am going to get one of those regulators. Thanks keep the info coming.
06-11-2005, 09:07 PM | #16 |
I took everyones advise and fixed a couple vacuum leaks, put on the regulator and it is set at 5psi, put all new plugs gapped at 40 in and it is running a lot better so far. It still seems to be boggy on the bottom end. In the high r's it runs really good. Just wondering how to get more snap out of the hole. Thanks
06-11-2005, 09:09 PM | #17 |
Your UncleBen
Try playing around with the FPR a little bit...Take it down a 1/2 psi or 1 psi and try it again.
Also might want to check on the timing again. Maybe the advance is off a bit. lata CHRIS
68 C10 shortbed -- Street/Strip Last edited by SweetandLong68; 06-14-2005 at 01:17 AM. |
06-11-2005, 10:35 PM | #18 |
What is a good average setting on the timing for these things. Or just keep playing with it?
06-14-2005, 12:08 AM | #19 |
Just bumping this up as I want to know if it worked out in the end. The fuel pressure regulator that is. I have a similar problem.
1968 Chevy - 292 with a powerglide |
06-14-2005, 01:19 AM | #20 | |
Your UncleBen
lata CHRIS
68 C10 shortbed -- Street/Strip |
06-14-2005, 12:23 PM | #21 |
how much pressure does the mechanical fuel pumps produce? I thought they produced 5 psi? does it produce a constant pressure, or does the pressure icrease with engine rpm? Would a pressuure regulator help me get better gas milage out of my truck?
1972 chev c20 2wd lwb 350v8/th350. (dad's)1970 gmc longstep (9ft commercial bed), 1 ton, 2wd, 350/th400. |
06-14-2005, 01:25 PM | #22 |
I have a stock fuel pump on my truck and it was pushing about 8psi. And yes the regulator helped out a bunch so far it looks like. Now I 'm just playing with the timing.
Hey sweetandlong what do you mean about the 32 total advance. Mine is set at about 12 degrees right now with the vacuum advance off. Thanks |
06-14-2005, 01:30 PM | #23 |
I will be putting one in my truck soon
06-14-2005, 07:55 PM | #24 |
Your UncleBen
I am telling you guys A FPR is a must have on the Edelbrock carb...No matter what. Just make sure you get one with some sort of gauge so you know what fuel pressure you have. If it was a Holley or a Q-jet I would say not to worry about it. But it can't hurt in any situation no matter the carb. It is just that Edelbrock carbs dont function to their maximum with too much fuel pressure. 4-5psi is all they need.
lata CHRIS
06-16-2005, 12:23 AM | #25 |
I put a Holley fuel pressure regulator on to see if it would help my problem. It may have helped a bit but I think the engine is still running rich. The exhaust smells rich to me.
I put a "T" in temporarily and a guage on to see what the pressure was after the regulator. It was about 5# so I adjusted it down to about 3# and the engine still seems to run about the same. No starving for fuel. I have noticed that the pressure builds to about 5# after I shut the engine off. I assume this is due to heat. I am uncertain as to what I can do about that. One of my problems is that the engine is hard to start once it is warm. I have to hold the gas pedal down in order to start it. That leads me to believe that fuel is getting into the manifold while the engine is off. Anyone have ideas on how to stop that?
