Old 06-09-2005, 08:16 PM   #1
Long Roof
Old School, New Style
Long Roof's Avatar
New Guy
Hello all. I posted this on the other board. Check it out.
http://67-72chevytrucks.com/vboard/s....php3?t=159463
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 06-09-2005, 08:56 PM   #2
RANDY COX
RANDY COX's Avatar
Hey welcome from VA,Really nice burb you have.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 06-10-2005, 10:03 PM   #3
benscool1
benscool1's Avatar
Cool burbs, sent you a PM.
Ben
84 C10 Silverado
14 Silverado Z71
benscool1 is offline   Reply With Quote
Old 06-11-2005, 07:49 AM   #4
gregfull
gregfull's Avatar
Welcome to the board! Nice 70 burb! I'm working on mine too.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 06-11-2005, 11:59 AM   #5
Long Roof
Long Roof's Avatar
Hey gregfull, I browsed about your burb link and all I can say is WOW. I think you may have more in the 502/700 combo than I payed for the 70 burb. I love everything you have done so far.
Aaron
P.S. I like the black/red 2tone shown in your avatar. I was thinking of a black/silver or black/burnt orange 2tone when I repaint.
The Good:
The Bad:
The Ugly:
Old 06-14-2005, 11:38 AM   #6
grebus1
grebus1's Avatar
Welcome to the board--nice Burbs. I'm curious about the folding rear seat setup and how the brackets that hold the upper part are attached. If you get a chance, could you post some close-up pics of the brackets and some pics of the floor underneath the seat with the lower part folded forward? Thanks in advance.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 06-14-2005, 06:50 PM   #7
Long Roof
Long Roof's Avatar
Here are the pictures of the rear fold down seat. It has a piano hinge along the foor edge. I am actually considering going with four buckets and a third row bench in the future.
Aaron
The Good:
The Bad:
The Ugly:
Old 06-14-2005, 06:52 PM   #8
Long Roof
Long Roof's Avatar
More pics
The Good:
The Bad:
The Ugly:
Old 06-15-2005, 08:08 PM   #9
bagged91
Out draggin'
bagged91's Avatar
Thanks for the pics Aaron. I am seriously thinking of doing this to mine. The original seats are a PITA to take in & out and carrying anything long is a hassle with them. This would make it easy. Does it feel like you are sitting on the floor without a riser on the bottom of the seat?
L8R - Joe
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 06-16-2005, 06:33 AM   #10
4x4Poet
That second seat is fantastic. Is that out of a '70s burb? Could you provide the vehicle source, please.
I'd also like to know if the bottom brackets were bolted to factory captive nuts or were the holes in the brackets used as templates to drill holes thru the floor for bolts and nuts? I'm interested in whether the seat brackets use the factory's reinforced metal for strength purposes? Excepting the piano hinge, of course.
On the top seatback catches, do those simply have holes drilled thru the inner sheet metal with bolts and nuts used?
What a convenient looking setup. Must make it a whole 'nuther truck that can take a 4'x8' sheet of plywood with the seat folded down. Thanks for the pics and
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 06-16-2005, 05:38 PM   #11
Long Roof
Long Roof's Avatar
I am not sure what exact year the seat came from as I bought the burb this way. I suspect mid to late 70's. The seat is at normal height and works well. The floor brackets required new holes in the floor board and large plate washers were used below. On the outer brackes a 1/4" or so shim was used between the floor and the bracket. The upper latches were bolted to the inside sheet metal.
Hope this helps.
Aaron
The Good:
The Bad:
The Ugly:
Old 06-18-2005, 11:24 PM   #12
72LoBurb
Yup, I'm comp-useless
Longroof, thanks for the info and pics on the rear seat.
I guess my 90 will be sacrificing more than drivetrain for the 72.
I, also just picked up some newer Tahoe seats (powered)and console for the front.
BTW, the 'burb looks great.
72LoBurb is offline   Reply With Quote
