Blazer Bedsides vs. Truck Bedsides
I have heard a few people say that they were going to cut down truck bedsides to fit their Blazer. Do they only need to be cut down in the front? or do you have to cut out a section behind the wheelwell also?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
You only need to cut down the front if you use SWB bedsides. Once you cut them down you have to fold the metal 90 degrees which is alot harder then it sounds.
How muck shorter is a Blazer bed compaired to a short wheel base truck.
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
