Premium Level Member
PICS WORKING NOW! The Poor man's one person top remover in a couple of minutes
Once unbolted, I am able to remove top in a couple of minutes with this setup.
-Four 5gallon buckets -four 4x4 post -four bags of quick set cement -two 2x4's 1)I set the 4x4 post in the buckets with cement, cut to a length that extend just above the top part of the blazer rear cab(not the top). 2)I set up the post at each corner corner of top. 3)From inside cab, I slip the two by fours under each end of top, lifted a bit to rest it on the 4x4 post(that are in the buckets). 4)The top is not just an inch or two above the k5. I can pull out of garage or pull back in and just park under the top. I drilled some holes thru the 2x4's into the 4x4's and dropped a bolt(loose) into as a safety measure, but it pulles right out for quick release. I've had it setup for a couple of weeks with no problems. The buckets are weighted sufficiently at all four corners to support the top without being shakey. It takes me 60 seconds(once unbolted) to remove top now, or put back on, and it take very little space. This setup took me about an hour to setup, can be moved, works in a sideyard, backyard, garage or driveway and if i move, the buckets come with me and have carrying handles! pic1 pic2 pic3 pic4 lastpic with me parked under it from inside
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, Last edited by jakeslim; 06-12-2005 at 08:45 PM. |
Sounds like a good set up to me!!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
good helpful tip!
Thanks!
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 |
SKINNY TIRES RULE!
How about some pics?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Now there's an idea! What about the rollbar?
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
The Blazer King
I have a similar setup in my yard. Did this a few years ago. I used 6 landscaping timbers to construct the frame and 2 to slide under the top. Mine is very tall though. I can post my setup this weekend.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
![]() More pics please.
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
Pics link added in original post.
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
not working for me
link to pics not working for me.
Bob |
#10 | |
User #12137
![]() Join Date: Apr 2004
it didnt work here eather ![]() |
Link worked, but no pics of your top lifting setup....
Like the blue plaid seats.
1969 K5 Blazer CST Always waiting for the Puget Sound sun..... |
dont you guys have friends???? That's how i used to get my top on and off before i sold it to a member in this thread
#13 |
We want to keep our friends, that's why we need a system to remove and store the top. (Also looks cool!)
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
#14 |
I got the pics to work now. The bolts at top fall in as pins. It is much sturdier than it appears.
#15 | |
#16 |
same here, if some one can see these please post them
#17 |
arrggghhh....ok, tried with link again to my yahoo photos. Someone try and let me know if they work!
#18 |
ran out of money
they just worked for me, nice set-up
Modify everything, leave nothing alone!~ ![]() ![]() |
#19 |
User #12137
they work now i just looked at them
#20 |
Not a bad nut after all..
The pictures don't work for me?
#21 |
I get this message when I click on the pics:
"The page cannot be displayed"
#22 |
just go here!
Go here to see pics on CK5
#23 |
< 69 Blazer
I really like that idea!
My only problem is that I have a roll-bar and will have problems getting the front 2x4 in. ![]() |
#24 |
Sell it before it's finished
If your rear seat is installed you will have to make it tall enough for the front 2X4 to clear it. I figured this out as I tried to drive out from under a similar set up.
#25 |
bahh i'll do it! thanks guys
![]() Last edited by Medicanman71; 06-13-2005 at 03:24 PM. |
