How does the water flow into the intake
This is a dumb question so here goes. How does water flow into the intake? Does it wait for the thermostat to open?
thanks
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Water flows into the intake manifold from the heads, through the thermostat, and back into the radiator.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console 65 C10, 350TBI, 700R4 (work in progress) |
So it pulls the water from the bottom and spits it back out through the top. And the thermostat allow more water to flow when it opens?
![]() Join Date: Mar 2003
Any hose fitting into the water pump is suction. Pushes into the front of the block and flows from there. When cold the water usually by passes into the heater core. Big blocks have a bypass hose at the intake into the pump.
That's it. Thermostat holds the water in the engine until it reaches the set temperature of the thermostat.
