06-10-2005, 12:32 AM | #1 |
Professional Grade
More Progress
Check it out!
Engine is in, TPI is on, and everything is wired up in the engine bay, woohoo! If I can find some EFI burb fuel lines, the serp stuff I need and sort out the nightmare on the inside, I may have her running by Sunday Night Sorry for the crappy pictures, when my digital uses the flash, it takes really gross pictures... I'll push it out and get nice ones sometime this weekend
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 06-10-2005 at 12:33 AM. |
06-10-2005, 01:52 AM | #2 |
Stepsides RULE
man that's gonna be cool.
Have I mentioned that's gonna be cool?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
06-10-2005, 02:19 AM | #3 |
Until Seventy Times Seven
Looking sweet. Keep up the progress.
I've lightened up your pics a bit.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
06-10-2005, 02:49 AM | #4 |
Still drivin' a Rat Rod
Looks great.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
06-10-2005, 04:08 AM | #5 |
Project 2 Resume
Looks great. What's the stock fuel pump for?
John 1984 C30 Chevy Crew Cab Dually 1998 Jeep Cherokee 4x4 2004 Chevy Trailblazer 4x4 (wife's) 1970 Mustang FB fully tubed (getting 521 BBF & powerglide) 1978 Nova 2dr (going BBCaddy & S.P. th400) 1984 Monte SS (circle track car) |
06-10-2005, 08:04 AM | #6 | |
yeller
Also, since you have it this far apart, why not paint the firewall a semi or flat black to clean things up a little??
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
06-10-2005, 10:09 AM | #7 |
Professional Grade
I still plan to clean up the firewall, thats why I have not been hooking up wiring inside of the cab as I go Just gonna pull out, mask then paint the firewall semi-gloss black
And yeah, I wouldn't mind the block off plate! Thats all that pump is doing. I didn't take it off cause I didn't have anything else to put into it's place, and I was too poor at the time to buy anything, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
06-10-2005, 10:42 AM | #8 |
Chevys Kick A$$
Sweet looking engine setup. Making some good progress. Wow the inside of your truck does look like a wiring nightmare.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
06-10-2005, 01:06 PM | #9 |
EFI into non-efi cars are FUUUUUN... NOT
Good work, I know first hand that those swaps can be a little discouraging at times.
Daily Driver: 1992 Blazer dropped on rallys Project: 87 GMC shortwide, About to get a little boost |
06-10-2005, 06:15 PM | #10 | |
Project92 SWB stepside
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
06-12-2005, 12:50 AM | #11 |
North Coast, baby!
Can you say wiring nightmare? I give you all the credit in the world Russell. That is "professional grade".
Brad 79 Scottsdale C20 350/350 3.73's Still running full CA smog gear! |
06-12-2005, 01:44 AM | #12 |
Professional Grade
Well, I got most of the interior wiring sorted out now. However, I gotta get her done faster than I was originally expecting -- I blew the 305 in my 89 up tonight. Not a chance she'll ever run again, bent a couple connecting rods, then shot them through the pan after blowing a headgasket tonight
06-12-2005, 02:07 AM | #13 |
Is that a gm p/u cruise module i see on the firewall....hhmmm.
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
06-12-2005, 02:14 AM | #14 |
Professional Grade
That it is Should work perfectly with the VSS I am running
06-12-2005, 02:37 AM | #15 | |
Russell, looks great man, i hope my wiring looks as neat as yours does. |
06-12-2005, 02:51 AM | #16 |
Professional Grade
Jeremy, I have not found the wiring to be overly difficult by any means. The truck's factory wiring has been much more of a challenge, lol
Most of the EFI wiring goes straight from the ECM to an actuator, or from a sensor straight to the ECM. That and a couple fused power wires. Pretty simple actually!
06-12-2005, 03:07 AM | #17 |
Truck with tbi requires a 2 pulse vss....on the other hand a tpi requires a 4 pulse...what are you up to...? And what application ecm are you using where you can use that cruise unit....i'm thinking the old trucks used a DRAC starting in 90-1...but i'm not sure if that carried over into the newer truck body style?
DW
06-12-2005, 03:11 AM | #18 |
Professional Grade
The TPI I am running uses a 2 pulse VSS. From 90 up, they began using the 4 pulse per mile VSS. My truck has a stock VSS behind the speedo, which is the exact same thing the first TPI cars used.
If the cruise does require a 4 pulse signal, then I've got a DRAC I pulled outta a small GM car that converts a 2 pulse signal to a 4 pulse signal, along with some 2 pulse outputs. Should work just perfectly
