Old 06-10-2005, 12:51 AM   #1
fossilrunner
fossilrunner's Avatar
body drop
what do you have to do to do a body drop
71 chevy lwb w/ 350,750 holley 4150,edelbrock performer rpm,full 2 1/2 exhaust exit out side,6-8 drop,rally wheels.-SOLD
74 Chevy nova-355 with a little nitrous
78 GMC Jimmy 4x4-Factory 400 and all stock.
fossilrunner is offline   Reply With Quote
Old 06-10-2005, 10:31 AM   #2
TOYOTA61384
What year truck do you have? Most of these era trucks bodies are already very similar heigt to the frame, not requiring a body drop. If you are set on doing one though it is a pretty involved process. You have to cut out the entire floor and section everything accordinly to the desired height, including the firewall, bed, core support etc. Like I said, a preety extensive job, that on these trucks shouldn't be required to lay rocker. Hope that helps.
Robert
TOYOTA61384 is offline   Reply With Quote
Old 06-10-2005, 01:19 PM   #3
XXL
Seņor Member
XXL's Avatar
Thread is no longer on the board, but you might contact lotik (he doesn't frequent the board any more, I believe). Click on the Members List link above and search for him alphabetically. Then shoot him a PM or email and see if he can point you in the right direction.
XXL is offline   Reply With Quote
Old 06-10-2005, 03:48 PM   #4
screamin_c102
screamin_c102's Avatar
Can't you install thinner body mount rubbers on the core support and cab,effectively dropping the cab/front clip down on the frame? Then modify the bed mounts or raise the bed floor to achieve the same thing? I see at least an inch if not more that could come out of my mounts, they are pretty tall.
Just a thought............
screamin_c102 is offline   Reply With Quote
Old 06-10-2005, 06:29 PM   #5
fastbagged68
fastbagged68's Avatar
Screamin C10- you hit the nail on the head! Exactly what I did on my shop truck!
fastbagged68 is offline   Reply With Quote
Old 06-10-2005, 08:52 PM   #6
69 longhorn
Thinner mounts wont gain you too much, without setting the cab right on the frame. I did a 1 1/2 " channel job on my 69.....it dont sound like much, but she also has a 4" chop top. You run out of room in a hurry, if you arent careful! My method didnt booger the complete cab, but just the center section of the floor. Lots of work. but little cost out of pocket. I agree with XXL....talk with Lotik on that 3" stock floor body drop that he did on his truck......slicker n chit, & he didnt loose any room inside the cab (as far as seating). There was a good amount of frame work on that drop tho best of luck, L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
