06-10-2005, 12:53 AM | #1 |
Just Don't Stop!
what holds armrests to door panel?
I was wondering how exactly a factory arm rest ataches to the door? Is there some sort of fastner that secures it? My truck didn't have factory armrests but I bought some 66 style armrests and I wondered how they 67-68 armrests were mounted from the factory.
Anyone have a picture? Thanks!
1968 C10 build in process TT LSA/6L90e/9" |
06-10-2005, 01:09 AM | #2 |
Where's my beer?
2 screws hold them in place, I'm not sure but I think the screws go all the way through the door panels and secure into the door itself.
Edit: I was thinking of '72 panles, 67-68 bolt only to the metal door panels.
Paul How do you make the invisible, visible?.........You take it away. Last edited by chevy_fatman; 06-10-2005 at 01:10 AM. |
06-10-2005, 01:31 AM | #3 |
On my '71 the screws go clean through to the door itself, they too have the metal panels.
06-10-2005, 01:34 AM | #4 |
Pull the door panel, you'll see two square holes in the door. Trucks with arm rests had caged nuts in these holes with 1/4-20 threads. I did this on a 67 recently. I welded flange nuts in the holes and drilled corresponding holes in the door panels. I used repro 67 arm rests, the 66 screw holes may not line up.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console 65 C10, 350TBI, 700R4 (work in progress) |
06-10-2005, 10:02 AM | #5 |
Just Don't Stop!
Simple enough, I'll just weld in some flange nuts then...
Thanks.
06-10-2005, 10:30 AM | #6 |
#16876
You can also use nylon push in nuts. Did on mine and they worked great.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
06-10-2005, 12:34 PM | #7 |
Where's my beer?
I was going to say the same as Sillyoldman, you can go to the parts store, get the push in nuts, the exact ones you'd use to mount a liscence plate, that's how mine are mounted, it works perfect.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
06-10-2005, 01:21 PM | #8 |
Seņor Member
My answer of "friction" would have been better as the first reply. But I missed my window of opportunity. I've used the standard license plate square inserts before... most auto parts places should have them.
edit: Looks like 70 shorty beat me to that one as well.
06-10-2005, 02:41 PM | #9 |
Just Don't Stop!
I thought about that, Just didn't know if that was strong enough to support the abuse of an armrest, especially when you use them to pull the door shut and stuff.
Thanks for the info guys!
06-10-2005, 08:32 PM | #10 |
Where's my beer?
Hey first gen, my armrest is actually only attached by the front screw, the back one acutally pulled all the way thought the armrest, but it's what I pull to close the door, so even with just one, its fine (at least for about 6 months that it's been that way).
