Old 06-10-2005, 01:43 AM   #1
skokie
skokie's Avatar
Bad Thermostat?
I got the intake all done and fired it up tonight. Temp guage got to almost H then I shut it down. I checked the top radiator hose and it was still flexible like there was no water coming through. I filled up the radiator before I started it. Could it be a bad thermostat?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 06-10-2005, 08:01 AM   #2
neonlarry
neonlarry's Avatar
You could have an air pocket under the t-stat (this can cause it not to open). I like to drill a small bleeder hole in them so this won't happen.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-10-2005, 10:16 AM   #3
skokie
skokie's Avatar
Im going to change out the thermostat tonight. Where would you drill this hole on the thermostat?
68 build thread
Old 06-10-2005, 11:22 AM   #4
jhow66
jhow66's Avatar
see if this will do
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-10-2005, 11:27 AM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
for 4 bucks put a new one in
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-11-2005, 12:10 AM   #6
skokie
skokie's Avatar
New superstant 180 in and problem solved. The other was was stuck. Not sure why. It wsa brand new.
68 build thread
Old 06-11-2005, 09:20 AM   #7
Blue4x4
Blue4x4's Avatar
I went thru 4 t-stats. Then drilled a small hole in the first one.......It worked for me.
Blue4x4 is offline   Reply With Quote
Old 06-11-2005, 12:50 PM   #8
pjmoreland
pjmoreland's Avatar
I have a suspicion that if intake manifold gaskets are used that block the heat riser passages that run through the middle of the manifold, the thermostat has a hard time warming up when there isn't any coolant/water in the manifold yet. I've struggled with this issue many times. I like the idea of drilling a little hole in the thermostat.
pjmoreland is offline   Reply With Quote
