06-10-2005, 06:03 AM | #1 |
First Mod..Brakes
Ive decieded that the first mod I want to do on my 70 C10 is disk/drum and switch to 5 lug. What is the easiest year to rob from for this conversion? Do any of you have a parts list? Is there any direct swap axles? I plan on going with 3 inch spindles in front and coils in the back. I figure this would be the best starting point for where I want to end up. Thanks for any help.
06-10-2005, 07:06 AM | #2 |
blood type; Retumbo
hit the bone yards & pick up a complete front suspension from any 73-87. 6 bolts & 2 hoses and its outta there. make that 8 bolts, forgot about the shock uppers. mine is from a donor 80 C10. made a trailer out of the back half. ($30 trucks are cool)
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
06-10-2005, 09:05 AM | #3 |
Questionable
There's a really good topic on this (with pictures) over in the FAQ section of the forum. It gives a lot of details on this swap, options and whatnot.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
06-10-2005, 09:47 AM | #4 |
Or.... You can keep the six lug axles and use 71-up spindles lowered if you like, and components coupled with 1990 3/4 light duty 2wd truck rotors ($53 each) and maintain 6 lug wheels and look original for your 1970, but you will need to buy different hoses- GMC pauls $115- braided, and get a prop valve and you have disk brakes and 6 lugs no need for new wheels or to buy new axles.
06-10-2005, 11:06 AM | #5 |
Member #1049
A 1970 rear end is a one year only housing.. it is the same width as the 71 and up just 6 lug (67-69 6 lug rear ends are narrower) .... you can use any 71 - 80 12 bolt 2wd 5 lug axles and drums.. just make sure if you find a 73 up rear end and it has the 3 inch brakes, get the backing plates and hardware too.. The easiest front conversion is from a 71 - 72, at least for the brake booster and steel lines.. most everything is a direct bolt in..
06-10-2005, 05:22 PM | #6 |
Shifty, can you set me up with a link? Maybe I just dont know how to use it yet but I clicked on FAQ and searched for "brake", "disk brake", "brake conversion" and "DAMNIT" all with the same "Sorry - no matches. Please try some different terms." results.
06-10-2005, 05:45 PM | #7 |
my gas saver
hey TN70, if you're close to nashville/clarksville, i've got an entire disk to disk front still on the xmember you can pick up for $50. voila, your front will be done. sorry, i already sold the rearend.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
06-10-2005, 05:49 PM | #8 |
my gas saver
here's the brake swap. http://www.67-72chevytrucks.com/vboa...d.php3?t=35042
06-11-2005, 01:33 AM | #9 |
Thanks. I may take you up on that front end. It may be a few weeks before I have the money. Im going to check around local also. I think a buddy of mine may have a whole parts truck. Im in Chattanooga so its a little bit of a ride to Nashville. Ive only been to Nashville one time but had a blast while I was there.
06-11-2005, 01:35 AM | #10 |
What if I decieded to bag it, would I still need drop spindles at all? I was thinking if I run it low alot with stock ones it would mess up some front end geometry or something
06-12-2005, 10:15 AM | #11 |
06-12-2005, 10:35 AM | #12 |
The LuvShack Garage
2THE BOARD FROM WEST 10-UH-C
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-12-2005, 11:51 AM | #13 |
PROJECT 7DEUCE
Welcome to the board ... You do not have to have dropped spindles to run air bag's
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
