Old 06-10-2005, 09:10 AM   #1
motocrosschump
Is there a limit to the number of questions..
I can ask...lol..I had an small oil leak..can't decide whether it was the oil pan or the oil pump. Well I went to replace the oil pan gasket..(what a pain) its a 250 (6) what all do I have to take off to get the oil pan out?
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 06-10-2005, 09:34 AM   #2
shifty
Questionable
shifty's Avatar
Here's some stuff I found using the Search feature:
Originally Posted by Longhorn Man
cableguy0 hit the nail on the head. On a 2 wheel drive, you can't drop the oil pan out without jacking up the engine.
Originally Posted by COBALT
When I replaced my oil pan back in November I unbolted the engine mounts, AND loosenedthe transmission crossmember mount (don't forget that one), and used a flat piece of wood with a rubber mat on top to jack up the engine by the ballancer. I normally wouldn't recomend that, but hey it's a small block, and I didn't want to yank the engine.
Here, it's easier. Just put the block and matt under the oil pan, and raise the engine a couple of inches.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-10-2005, 09:35 AM   #3
smokekiki
Mike
smokekiki's Avatar
Sorry You hit Your limit! Take the starter off.Unbolt the motor mounts.Jack the motor up and put a piece of 2x4 between the mounts and block.Remove the flywheel cover.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 06-10-2005, 09:53 AM   #4
super72bb
I don't know off hand if they are availible for the 6Cyl but, I just replaced my oil pan gasket on my 350 and I used a 1 peice rubber gasket made by Fel-Pro. It was kinda pricey compaired to the standard 4 peice but well worth it. It was a snap to install once I finally got the pan off and no leaks.
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK.
My build thread:
http://67-72chevytrucks.com/vboard/s...=1#post7120181
super72bb is offline   Reply With Quote
Old 06-10-2005, 08:49 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Myself, i have no idea if an inline oil pan can be removed in the chassis...the quote of mine up there was for the small block equipped trucks.
