06-10-2005, 11:46 AM | #1 |
radiator stop leak...what's the best product?
Unfortunately it appears the '67 will need a new radiator. Drips a good sized puddle every time ya shut it down. Truck is still entirely useable as is, just needs a little coolant every week or so (about 1/4 gallon every coupla weeks).
So what's the best product to slow the leak and help me put off changing this thing till cooler weather? |
06-10-2005, 11:51 AM | #2 |
Lovin' Life in Miss.!
Doesn't sound too bad. don;t use the sealant. Just take the radiator to a radiator shop and have em fix it for you. $35 last time I took one in.
The truck... you hear that? No really, you did hear that?!!! |
06-10-2005, 12:18 PM | #3 | |
YES_____NO
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board Last edited by Mongo; 06-10-2005 at 12:19 PM. |
06-10-2005, 12:20 PM | #4 |
Stop leak stuff is just a bandaid fix. Radiator is pretty easy to remove and replace. I would fix the radiator, ask them to just fix the leak. If they give you the deluxe fix, cooking it out, removing tanks and fixing etc, it would cost more than its worth, Just buy new one then. Having said that, I have used Bars-Leak several times for fixing leaking freeze plug that I was too lazy to replace, it has worked for that and didn't seem to hurt anything, however, if you ever have the motor apart, you will find this black gooey gunk has settled to the bottom of the water jackets in the engine.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
06-10-2005, 01:33 PM | #5 |
Cowboy Fan for Life!!!!!!
What they all said. Stopleak is like putting a bandaid on a broken arm, and usually just as effective. I've had more backyard mechanics tell me to use anything from stopleak to eggs to black pepper to stop a radiator leak. Save yourself time and trouble, take the radiator out and have it repaired. Most radiator shops around here would fix that up in a couple of hours and i'm back on the road that evening for under $40......Jerry
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
06-10-2005, 03:39 PM | #6 |
1-888-252-0333 is the # to Radiator Doc. Bought 4 core "Modine" rad from them last year. $165.00 shipped to my door. Took about 3 days. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
06-10-2005, 04:21 PM | #7 |
my gas saver
if you are near nashville, my buddy is manager of keystone automotive. call em at 615-226-9090. if you go there ask for Jason and tell him Eric sent ya. he'll get you a modine with lifetime warr for about $115. if you want a used one, i've probably got one layin around here for a couple of bucks.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback Last edited by CHEVYE; 06-10-2005 at 04:22 PM. |
06-10-2005, 05:02 PM | #8 |
Thanks for the input. I'll def buy a new one instead of patching the old one. Figure with a 38 year old radiator ya never know if it'd spring another leak in a different place, then have to fix it all over again.
Don't really wanna use any stop-leak but it's worth asking just to see if there's any great new product on the mkt I aint aware of. |
06-10-2005, 05:12 PM | #9 |
Questionable
Sorta on-topic ... what's a good cleaner to put into your radator to flush your cooling system and clean it at the same time?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
06-10-2005, 07:19 PM | #10 |
Prestone makes a cleaner but I have heard it can be kind of harsh. I use Spic & Span, run it for about 20-30min then flush well. Great for cleaning out dexcool or the above mentioned Bars Leak put in by PO's.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-10-2005, 07:24 PM | #11 |
Yep, If your gonna do...Do it right. It will cost less than the tow bill if it gives up on the road.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster Last edited by sdkid; 06-10-2005 at 07:26 PM. |
06-11-2005, 12:31 AM | #12 |
if you need a band-aid fix for a little bit the only decent "stop leak" products are GM tablets or the stuff made by BG's.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
06-12-2005, 03:08 AM | #13 |
A problem with the stopleak stuff is that you may only need a pinch or two to plug the hole, but most people will put in the entire bottle. After the hole is plugged, the rest of that stuff just circulates in your system. It is supposed to harden when it contacts the air, so if you ever drain your cooling system, the sludge can harden up in your system somewhere. You could also pinch the leaking tube shut and put some JB weld on it. I have seen that work before. I replaced the radiator in the 69 a few months ago, one of the tubes was leaking, I tried to gently plug it with a center punch(just to see if it would stop), and the thing just crumbled and started spraying coolant everywhere. Good thing it was still cool, or that could have hurt. The radiator was rusted all to heck. Replacing is definitely the way to go.
If at first you don't succed, break something! |
