Old 06-10-2005, 01:03 PM   #1
kw
kw's Avatar
88 Burb, runs rough at start, gets worse
Hey all,
I'm trying to troubleshoot a problem I'm having with my 88 GMC suburban.
When it starts, the idle is rough, when I start to drive it sometimes backfires, but runs rough and seems to lack power. If I romp on the gas it seems to get up and go OK, but when at around 45-55 mph it seems to hesitate and run rough. I checked the plugs and they seem OK. Thinking it might be water in the fuel, I've been running drygas and fuel injection cleaner every tank and still it does it.
I don't have a shop manual for it yet, and was wondring if there is a systematic approach to repair this without replacing every sensor in the vehicle. Any ideas?
The engine is fuel injected and stock. 94k miles.
I was going to start with the fuel filter. Where is it located?
Thanks in advance for any help.
Kurt
kw is offline   Reply With Quote
Old 06-10-2005, 03:28 PM   #2
86 GMG
fuel filter will be located some were on the passenger side frame rail about mid-way back
if anyone else can direct him more accuratly please do the filter wile look like a pop can cut in half (best lamons term i could think of) sorry it may have a protective plate or panel covering it from any road harm
best of luck
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 06-11-2005, 12:17 AM   #3
f.monroe
f.monroe's Avatar
If it isnt kicking up a Check Engine code I would try a new set of plug wires . If it is kicking a code most Auto part stores will scan it for free . Frank
f.monroe is offline   Reply With Quote
