Old 06-11-2005, 01:00 AM   #1
jacill
MSD Ignition box for my truck????
I have a buddy that is wanting to sell me his pretty much brand new MSD ignition box for $100. I don't know anything about them, so is it something that I could use or what. I have a 350 with a little bit of work done to it. It seems to always run rich, he says that this box will help that. Any ideas or comments are welcome. Thanks
jacill is offline   Reply With Quote
Old 06-11-2005, 01:18 AM   #2
dtlilly
dtlilly's Avatar
A new MSD 6A ignition usually sells for $160+. You will need a high output coil to complete the set-up. Always running rich is an unburned fuel problem, and better spark is only part of the cure. You may have other timing or carb issues that is associated, and the ignition box is not a cure all.
dtlilly is offline   Reply With Quote
Old 06-11-2005, 01:26 AM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
blaster 2 coil runs about 35 bucks get that if you run a tach you might need a adapter for the wiring
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-11-2005, 03:56 AM   #4
68LSS1
68LSS1's Avatar
I'd say go for it if it is a 6AL (built in rev limiter).
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 06-11-2005, 06:35 AM   #5
Bowtie67
Bowtie67's Avatar
Unless you have a highly moded engine and run at the drag strip you will find that is just money wasted. A good HEI complete (less wires) cost less than $100 new unless you want to pay for a name brand unit & will work great in most stock & the average modified engine.
http://www.fastengineparts.com/produ...ew.php?id=1653
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 06-11-2005, 09:33 AM   #6
jacill
I have already converted the motor to HEI. I was just wondering if the box would add to it or not.
Old 06-11-2005, 10:23 AM   #7
cdowns
cdowns's Avatar
i think it'd be a big waste of money. wouldn't solve your fuel system problem and would probablly just cause you electrical gremlin problems in the future
NOT NEEDED ON LIGHTLY MODIFIED STREET ENGINES
Old 06-11-2005, 10:28 AM   #8
jacill
Sounds like a no go for me. Thanks guys
Old 06-17-2005, 11:31 PM   #9
twisted racing
hell i say go for it, it is a lot better then a HEI, a good HEI will not stand up to MSD And It will kinda fix your problem, It will be money well spent
twisted racing is offline   Reply With Quote
Old 06-18-2005, 02:34 AM   #10
pissonNOS
senior member
pissonNOS's Avatar
how would this cause electrical problems? theres only 4 wires is there not if i recall when i hooked mine up
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-18-2005, 02:24 PM   #11
Purs
Got Big Block?
Purs's Avatar
he's probalby talking about the numerous people who have been stranded when there MSD box just croaks. It's just one more thing that can fail. I certainly won't go so far as to say it would be a big waste of money, but for your intended purpose I'd say that you wouldn't notice a difference. If you are running too rich the MSD might help a little, but like the others have said, you've got other problems that need to be addressed.
On a personal note, I've run MSD boxes on my last 2 engines. They were putting out 425 and 500 flywheel HP. I considered NOT running one on my current mill because I made 586HP with a standard HEI on the dyno. I changed my mind however and purchased a MSD 6AL for it mostly because it had a rev limiter built into it but also because I just "like" the peace of mind that my ignition system is "putting out."
If it's a 6AL then $100 is a very good deal. If it's just a 6A then it's still not bad. JMHO
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 06-18-2005, 11:07 PM   #12
Big Bad 1972 Blazer
Big Bad 1972 Blazer's Avatar
I agree with little bits and pieces of what's been said. First, I'd definetly go with the MSD box. 20 degrees of multiple spark firing vs a single pulse from a standard iginition improves power and makes for a more efficient engine...but...if you're buring that rich, it's probably a carb adjustment problem, not anything to do with the electrical or ignition system. I've never had any electrical problems associated with the MSD systems that I've owned either.
Anyway...just my $.02...
Big Bad 1972 Blazer is offline   Reply With Quote
Old 06-19-2005, 03:22 AM   #13
68LSS1
68LSS1's Avatar
One thing I'd like to mention also is that your MSD box failing should never leave you stranded. In fact, if you get a new unit it comes with the parts to mount on the coil which allows you to "bypass" the box if necessary and the instructions even tell you which wires to move to do so. That's just wrong information.
'68 Short Step
