Old 06-11-2005, 01:03 AM   #1
jacill
Spark plug is ugly!!
I have been having trouble with my truck running right here lately, no low end power. I pulled some of the plugs and got to #7 on my 350 and it was totaly black and had a chunky build up on it. Way to rich I'm assuming. Any ideas?
jacill is offline   Reply With Quote
Old 06-11-2005, 06:58 AM   #2
dwaite72lnghrn
Sounds more like a bad valve or valve stem seal, the valves(burnt or bent) are not allowing compression to burn or the plug wire/cap is bad. I think if it was a plug wire the plug would be wet and oily but no chunks.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 06-11-2005, 09:31 AM   #3
jacill
What is the best way to check that out?
Old 06-11-2005, 11:04 AM   #4
hgs_notes
GEARHEAD
hgs_notes's Avatar
Two quick checks would be to do a compression test on the engine, if thats good (all relatively even pressures) then just replace the plug wire and check it later for color.
HG
hgs_notes is offline   Reply With Quote
