06-11-2005, 01:45 AM | #1 |
tilt wheel
wanted to know wat year til colum will fit in my truck with little or no fab work its an1968 gmclwb 396 450hp turbo 400 stage 2 shift kit soon will have pics will be orange on bottom and black on top thanks for the help ive been reading posts for about 1year and it helped alot . also i have an 1985 truck will that colum fit thanks for the help
06-11-2005, 02:07 AM | #2 |
Welcome to the board from Wisconsin!
A tilt wheel from a 69-72 truck will be a direct replacement (plug and play). Any tilt from a truck newer than 1972 will have the ignition key in the column, and have you running wild to convert wiring, etc. A van tilt is a popular conversion, but it will require cutting the output shaft and doing other types of custom engineering. 69-72 truck tilts will fit any 67-72 trucks. The automatic tilts run $200+, and manual shift tilts run $300+. Converted van tilts run $100+ Last edited by dtlilly; 06-11-2005 at 02:08 AM. |
06-12-2005, 02:23 AM | #3 |
thanks for the reply i think i might try theone from the 1985 since i have one.
06-12-2005, 05:19 AM | #4 | |
06-12-2005, 08:12 AM | #5 |
Would be alot easier if you found a Van tilt. I just installed mine without any cutting in my 70GMC. The one I used came from a 78 Chevy Van, with key in the dash. Only 2 mods you have to do. One is collapse the outer steering arm, that's the one connected to the steering box, and relocate the neutral safety switch. I bought a "Lokar" switch that mounts on my transmission pan. The following thread helped me......
http://67-72chevytrucks.com/vboard/s....php3?t=147927 Steve
1997 GMC Sierra Ext 1965 Mustang |
