Old 06-11-2005, 12:05 PM   #1
GMan69
GMan69's Avatar
Alternator mounting bracket
With the original accessory drive setup, does the alternator mount to the driver side exhaust manifold or is there a lower bracket? LUV wants to convert to original short water pump setup so he can relocate the alternator to the driver side. I'm sending him some of the pulleys and an upper alternator bracket, but I can't remember how the alternator fastens at the bottom. Thanks.
George
George Morgan
Hernando, MS
'69 C-10 swb fleetside
'72 GMC swb Stepside
GMan69 is offline   Reply With Quote
Old 06-11-2005, 12:19 PM   #2
72402
Lower bracket bolts to front of head.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
Old 06-11-2005, 12:36 PM   #3
JimKshortstep4x4
Talking
67-68 alternators bolt to the exhaust manifold. The 69-72 alternator brackets bolt to the heads like this pic.
Jim
Old 06-11-2005, 10:44 PM   #4
GMan69
GMan69's Avatar
Thanks for the responses. The engine that was in my truck when I bought it was a '68 model 327, so the heads, 040 castings, had no accessory holes. I thought I remembered that the alt. bolted to the exhaust manifold and y'all confirmed that. Thanks again.
George
George Morgan
Hernando, MS
Old 06-12-2005, 01:33 AM   #5
tomatocity
tomatocity's Avatar
Jim
You just wanted to show off your beautiful frame off project. Very Nice!
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 06-12-2005, 01:43 AM   #6
67sss
67sss's Avatar
I have a 67 lwb 2wd drive truck with a 71 engine. How come when I put my alt. setup like the above pic, I can't get the p/s cap off the pump? It hits the bottom alt bracket .
67sss is offline   Reply With Quote
Old 06-12-2005, 05:26 AM   #7
JimKshortstep4x4
Talking
67sss,
I would check out the pump. The truck pump has the filler neck angled forward a few degrees which gives you the clearance to clear the bracket with the dipstick.
I can post a pic if you need it.
tomatocity,
You might be right!
Jim
